Hello Guest it is April 26, 2024, 05:33:19 AM
Author Topic: 9x20 Chinese Lathe Conversion  (Read 88934 times)
Re: 9x20 Chinese Lathe Conversion
« Reply #40 on: June 14, 2012, 11:17:40 AM »
Looks great !  Cant wait to see it moving.
JH
« Reply #41 on: June 15, 2012, 01:20:46 AM »
Thanks JH. I am getting close.
« Reply #42 on: June 19, 2012, 12:41:54 PM »
Made a PCB last week for all the buttons on the front panel:
Soldering was a pain with all the jumpers that were needed. It took a few hours spread across a couple of days, and this is after all the components have been soldered to it:
The buttons are tactile buttons and they will have caps with different colours. For the overrides I used mechanical encoders.
« Reply #43 on: June 19, 2012, 01:02:19 PM »
Have been working on the wiring for the past few days. Interesting how many wires there are for machine which merely has 3 motors. Here is the component plate, a moment before I mounted it inside the cabinet, with all the components wired:
And all this to eventually control 3 motors ;)
I decided that cutting power to the spindle drive on an Estop event was not what I wanted, since I didn't want the spindle to freewheel to a stop, but rather stop instantly, so I am using a contactor (bottom right) to cut the motor phases from the drive and switch in resistors between them instead, to dynamically brake the motor. I feel more comfortable with this.
« Reply #44 on: June 19, 2012, 01:25:32 PM »
Vice work Dan, very neat, tidy and compact.
Will be anxious to see this one finished !
Again, NICE !
Carry on,
Russ
« Reply #45 on: June 19, 2012, 04:05:19 PM »
Looking good Dan. Does the Ultra 5000 have limit inputs? I was thinking of using them to halt motion but found I didnt need it on the axis and on the spindles I have brakes.
« Reply #46 on: June 20, 2012, 03:43:47 AM »
Thanks guys.
Hood, the Ultra 5000 has an embedded controller and is intended for stand alone applications. It doesn't have any inputs/outputs tied to any hardware feature and it has a microcontroller which you can program in C to do whatever you want, so I believe you could program it for limit inputs. Are you suggesting this in place of disconnecting the motor from the drive on an Estop? Doesn't look safe to me...?
« Reply #47 on: June 20, 2012, 05:32:23 AM »
Was just thinking out loud and curious of what the 5000 actually were like in case I came across one at the right price ;)
My thoughts on previous builds was to cut the power to the drive(like I do) but if the friction of the slides wasnt enough to brake things instantly (or very close) I was  going to use the spare contact on the contactor to  apply the overtravel inputs thus allowing the drive to instantly halt the motor.
« Reply #48 on: June 20, 2012, 06:03:36 AM »
Be aware that the Ultra 5000 don't accept any external signals (step/direction or other). They were not meant to be used with an external controller. They do have an option for electronic gear follower, however, and this is the mode I am planning to use mine in.
And that is while the drive is not powered already? Not sure I would trust this. I have followed the recommendation in the Ultra manual for switching in braking resistors and it's been working great and I think I will stick with this approach.
« Reply #49 on: June 20, 2012, 04:31:55 PM »
How are you doing the follower? Using a SS and quad output?
Not reaally sure what you were meaning by "And that is while the drive is not powered already?"
What I was meaning was I was thinking of cutting the AC to the drive and at the same time having the spare contact of the contactor act as the overtravels into the drive. Hit the E-Stop, the drives AC gets cut, this will take a second or so to use up the power in the caps but with the overtravel getting seen by the drive it should stop instantly.
The resistors are a good way to go for sure. I dont see the wiring diag  in the manual I have but there are quite a few manuals on the 2098 drives so likely its in one of the others.
