Hello Guest it is March 28, 2024, 06:10:24 AM
Author Topic: Beginner Help  (Read 6068 times)
Beginner Help
« on: February 19, 2012, 03:42:52 PM »
I started playing with MachScreen, and can get the DRO, reset etc to show up. When I load in the screen in Mach, and I do reset, I can enter X1.0 and see the DRO respond. I cannot, however, get the arrow keys or number keypad to make the DRO move.
I assume I am doing something simple wrong here?
Geo
Re: Beginner Help
« Reply #1 on: February 19, 2012, 03:49:00 PM »
You need a jog on/off button in order to be able to jog.
Re: Beginner Help
« Reply #2 on: February 19, 2012, 04:24:32 PM »
Thanks Gerry, that worked.
Just for completeness:
For Reset Button, I used function "Std Reset", Standard Code 21. Also used LED function "Reset LED", OEM-Code 800.
For Jog Button, I used function "OEM Jog Mode Toggle, Standard Code 103. LED function "Jogging Enabled LED", OEM-Code 83.
Geo
Re: Beginner Help
« Reply #3 on: February 19, 2012, 05:00:22 PM »
Sounds like you're using MachScreen? I use Screen4, which uses different terms. In Screen4 it's just called Reset. THE LED is 800.
Jog is 103 with LED 83.
Re: Beginner Help
« Reply #4 on: February 19, 2012, 05:15:05 PM »
Yes, MachScreen.
Re: Beginner Help
« Reply #5 on: March 10, 2012, 06:34:30 AM »
Hi Brian,
Some machine plasma cutting used digital height control  for varies high level of metal
Can you show me how to set up on screen to use sensor ?
Thaks
Thuyen
