Are your slideways sticking or too tight on the gib , this can cause a buildup of pressure that releases in a jolt, you can see this on a DTI clock set against a block with the backlash removed first if you jog in very small moves in the same direction, the clock will not move and then suddenly jump.
Only my two penath,
