Hello Guest it is April 26, 2024, 11:21:56 AM
Author Topic: Homing dual axis issue  (Read 2824 times)
« on: February 14, 2012, 06:26:43 PM »
At first, sorry for posting the new topic that has been discussed dozen times (I couldn't find the answer)...
Here are the facts: hot wire foam cutter > X & slaved A, Y &
slaved B axis, home slave with master unchecked. 4 home sensors for each axis. When edit refallhome button (refcmbntn(18), (refcmbntn(9)) it homes and backs off onlly master axis, while slave axis remains over the sensor. Also there is a message: SHOMING_MODE_2_PART_2_COMPLETE: Home Switch Never Closed. Aborting. The weird thing is that Mach didn't tells axis to back off... Any idea???
P.S. The same machine worked fine with ss-PC-XP and after replacing with new win7 PC (with the same ss pcb) the issue appears
Cheers,
Re: Homing dual axis issue
« Reply #1 on: March 03, 2012, 04:05:13 AM »
Hi all,
Just to inform you that the issue has been solved, the problem was in SS plugin. Now we have proper homing again.
