Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portuguese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 25, 2013, 02:55:24 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
Brains Development
Arduino -> modbus -> Brain
Pages:
1
Go Down
« previous
next »
Author
Topic: Arduino -> modbus -> Brain (Read 1764 times)
oscbe112
Active Member
Offline
on:
January 28, 2012, 09:32:47 AM »
Hi Guys,
Building a arduino[modbus] based Pendant for my machine but has run in some trouble with brain, plz help
1.
I'm jogging the axis by buttonpress. When using the buttons I want it to jog while I press the buttons, just like the binded keys at my keyboard.
It starts jogging but never stops!
What am I missing?
# It haven't crashed. Everything else works.
# Keyboard jogging works
# "Cont jog" is selected
# According to control brain it all works, the input is turned on only when pressed.
# When trying in "Step mode" it works just fine, it steps the amount selected in "incremental step".
2.
I'm using 2 analog inputs FRO and Jog%. One of the registers has stopped working, when I use another one it works but this is strange. The Arduino handles this registers the same way. Is there a limit of registers you can use (I'm using 22)? Is there some known bug causing this?
3.
How do you configure brain to actuate a button on the screen that isnt in the buttonlist?
Pendant_test02.brn
(9.96 KB - downloaded 88 times.)
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
Re: Arduino -> modbus -> Brain
Reply #1 on:
January 28, 2012, 11:00:54 AM »
Hi Guys,
see below:
1. I'm jogging the axis by button press. When using the buttons I want it to jog while I press the buttons, just like the binded keys at my keyboard. It starts jogging but never stops! What am I missing?
>>>>>>>>>>>>>>>>>>in Brains there are "Stop Jog" commands as well, you will need to integrate that so it will stop moving when you let go.
2. I'm using 2 analog inputs FRO and Jog%. One of the registers has stopped working, when I use another one it works but this is strange. The Arduino handles this registers the same way. Is there a limit of registers you can use (I'm using 22)? Is there some known bug causing this?
>>>>>>Havent played with the ardino so couldnt tell you
3. How do you configure brain to actuate a button on the screen that isnt in the buttonlist?
>>>>>>>>No direct way to do that, the best work around, is to set an ULED with the Brian, then have the Macro-pump also execute the code that is in that custom button.
>>>>>>>>make sure you put an Interlock in the MP so that it will only "Hit" that code once per push and release of your button.
Scott
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
oscbe112
Active Member
Offline
Reply #2 on:
January 28, 2012, 12:50:43 PM »
1. Ok I got it. But having problem with the AND statement. It only works for one of the two inputs. See attached pictures
2. I suspect that the bug is caused on the other end.
3. Hmm..., no shortcut here
Thanks Poppabear
oscbe112
Active Member
Offline
Reply #3 on:
February 19, 2012, 04:54:22 AM »
Anyone that can help me with the
AND
statements?
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
Reply #4 on:
February 19, 2012, 09:01:00 AM »
ok, that is an easy one.......... hehehee
the issue is according to your screen shots, for your and to work, BOTH of your inputs have to be OFF at the same time, so that the inverts flip it and pass both of them as ON to your AND block. In both screen shots, one of them is ON, and the other is OFF.......
For the AND to function, with the invert on both its feeds being ON, you will need BOTH of your inputs to be OFF at the same time. The Brian only reads what is in the input, so your Arduino is the one "setting" those two inputs. So you need to look at your Arduino code, and when you want the JOGX in M3 to push the off button, then the Ard, needs to send two "0's" one in each MB register.
Scott
stirling
Global Moderator
Offline
UK
Reply #5 on:
February 19, 2012, 09:41:29 AM »
Hi Scott - I think what our man is saying is that in the bottom pic he's getting a "true" out of the AND gate and he SHOULDN'T be.
Ian
www.razordance.co.uk/THC.htm
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
Reply #6 on:
February 20, 2012, 08:36:19 AM »
Hi Ian,
Yeap, your right, sorry I missed that.........
Ok, do these 5 (possible) things to see if it resolves.
1). Go into editor, and delete your complete last rung, and redo it, see if it works then... If NOT #2.
2). Go into editor delete that last rung, then make a new brain call it part2 or what ever, and put JUST that problem rung in it... if not #3
3). If that fails, Edit the part2 brain, in where you keep your inputs, but pass that data (as a no-op) to 2 unused UDROs.
Then in the macro pump, write a interlock script that looks at those two dros, and does a button push depending on their and'ed value.
you can use "NOT" key words to in effect "invert" their value if your using them as Boolean's..... if not #4
4). Delete the entire brain, and rebuild a new one from scratch.......... if not #5
5). Scrap the Brian stuff, and just do it all in a macro pump, or periodic macro.
scott
stirling
Global Moderator
Offline
UK
Reply #7 on:
February 20, 2012, 01:50:04 PM »
Quote from: poppabear on February 20, 2012, 08:36:19 AM
Ian
oscbe112
Active Member
Offline
Reply #8 on:
February 26, 2012, 02:23:36 PM »
1. Fail !
2. Works
Its weird because I've already tried this, but well now it works!
Thanks for the help
zafarsalam
Active Member
Offline
Reply #9 on:
February 27, 2012, 09:07:13 PM »
I've also noticed that only the first 10 AND based rungs work in a brain. All the AND's after the 10th one don't get triggered in any case. I break the brain into 2 parts for them to work. Is it a bug with brains?
Zafar
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> CS-Lab
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Mach3 Wizards
=> Newfangled Mill Wizard
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
