Hello
Guest
it is
April 26, 2024, 12:53:48 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
SmoothStepper USB
(Moderator:
Warp9TD
Trouble with smooth stepper
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
Go Down
Author
Topic: Trouble with smooth stepper (Read 31236 times)
santosh
34
Re: Trouble with smooth stepper
Reply #10 on:
June 30, 2012, 09:36:17 AM »
have set it to 0 but i could not see any changes in RM value it shows same.
in general configation i saw there 8 bit one stop for serial output.
i dont know exact where i can find a bit about index pulse?
can u please guide me?
Logged
Carnoustie, Scotland
Reply #11 on:
June 30, 2012, 09:56:25 AM »
I am asking what hardware you are using for the index pulse, ie is it a slotted disc with an optical sensor?
Logged
santosh
34
Reply #12 on:
June 30, 2012, 09:58:33 AM »
i m using proximetry sensor
Logged
Reply #13 on:
June 30, 2012, 10:01:32 AM »
Does the spindle speed show correctly in Mach when you have it running?
Ok another question, in your PM you said you want to thread 500m but I am not sure what you mean, are you meaning a length of 500mm or?
Logged
santosh
34
Reply #14 on:
June 30, 2012, 10:05:32 AM »
when i use parrallel port that time spindle RPM shows correctly i told you i can thread 150 mm long length for longitudnal 6 mm pitch.
on parrallel port i cant do thread up to 500mm length and 5mm pitch. because after 150 mm length thread pitch shift. so i prefered to use SS.
Logged
Reply #15 on:
June 30, 2012, 10:07:32 AM »
Does the RPM show correctly with the SS?
Logged
santosh
34
Reply #16 on:
June 30, 2012, 10:08:49 AM »
yes it shows correct RPM
Logged
Reply #17 on:
June 30, 2012, 10:19:12 AM »
Ok I am needing to understand a bit more about what your problem actually is. I realise English is not your native language so it is not so easy for you but likewise it is not so easy for me to understand what is actually happening.
You say
"my threading stop while running for 1 or 2 second therefore threading pitch shift." Do you mean the SmoothStepper faults or does the threading just stop and stand still?
Are there any error messages?
Does the SS lock up?
Logged
santosh
34
Reply #18 on:
June 30, 2012, 10:25:48 AM »
no there is no any fault in smooth stepper.threading stop for one second in first depth of cut and continue withine second same cycle because of that our threading pitch shift in second depth of cut of cycle. this kind of thing happen every depth of cut. i changed ss board but same problem also. as well as i replaced ram of pc 1GB to 2Gb
Logged
Reply #19 on:
June 30, 2012, 10:35:48 AM »
What RPM are you threading at?
Logged
Print
Pages:
1
2
3
4
5
6
7
Go Up
« previous
next »
