Hello
Guest
it is
April 19, 2024, 07:08:46 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
SmoothStepper USB
(Moderator:
Warp9TD
Why Smoothstepper made a pause between commands ?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Why Smoothstepper made a pause between commands ? (Read 3004 times)
bluewave65
6
on:
January 11, 2012, 10:20:43 AM »
Hi everybody,
i got a problem with smoothstepper and mach .....
if i send to SS these :
G1 X49.914 F10000
G1 X49.914 Y0.042
He made a pause between them .......
How can i fix it ?
Is it possible ?
Logged
Carnoustie, Scotland
Re: Why Smoothstepper made a pause between commands ?
Reply #1 on:
January 11, 2012, 11:40:06 AM »
If it just a momentary pause it would seem you are in exact stop mode (G61) Change to Constant Velocity mode (G64) and see if that helps.
Logged
bluewave65
6
Reply #2 on:
January 11, 2012, 12:36:20 PM »
That`s the problem : I`m not in exact stop mode ............
Logged
Reply #3 on:
January 11, 2012, 02:25:13 PM »
Can you attach your xml and also the code that you are using and is it between all lines of code or just specific ones? Also is it just a momentary pause or is it longer?
Logged
Print
Pages:
1
Go Up
« previous
next »
