Hello
Guest
it is
March 28, 2024, 07:06:34 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
adding a second mpg
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: adding a second mpg (Read 2981 times)
comet
336
adding a second mpg
on:
January 01, 2012, 09:06:31 AM »
Hi,I want to have 2 mpg'd on my 3 axis mill,mpg1 will switch between Y & Z axis using 186 and 187 oems, but I want mpg to be on x only I dont really want to use 281 toggle axis for that.Any Idea?
regards
Tony
Logged
Re: adding a second mpg
Reply #1 on:
January 01, 2012, 09:16:06 AM »
Use dedicated pins for the X mpg?
Logged
comet
336
Reply #2 on:
January 01, 2012, 09:18:46 AM »
not really with you there Rich? dedicated pins? Im using a pci pp card to operate the mpg set up
Logged
comet
336
Reply #3 on:
January 01, 2012, 12:19:27 PM »
how do I dedicate the pins?
Logged
Reply #4 on:
January 01, 2012, 04:32:58 PM »
I use two MPG's and in Config>Ports & Pins> Encoder/MPG's....MPG#1 & #2 are enabled, use the same port but use 4 different
pin assignments for the A & B Pin#.
Logged
Print
Pages:
1
Go Up
« previous
next »
