Hello Guest it is April 24, 2024, 09:29:47 PM
Author Topic: M5 and M3 command getting lazy  (Read 2271 times)
« on: December 15, 2011, 01:02:34 PM »
I have a plasma table setup with a gekodrive and an automotive relay attached to the plasma cutter, however when I run a program sometimes the m3 commands are not caught and the plasma is left turned on during a rapid move causing a gouge or a cut right through the part. I was wondering if this might be caused by mach3 or the relay? my f5 command doesn't work anymore either.
Do you need my mach3 xml sheet?
