Hello Guest it is March 29, 2024, 09:44:06 AM
Author Topic: Scripter Compile Errors  (Read 16616 times)
« on: November 29, 2011, 06:55:03 PM »
Has anyone seen this error??
I get periodic scriptor compile errors in spindle .mis and when tapping in:M4.mis
Any ideas
Re: Scripter Compile Errors
« Reply #1 on: November 29, 2011, 07:36:25 PM »
Yup, I get those periodically, and got one today on M3.m1s.  The fix is usually to open the offending file with Notepad, and you should see a few garbage characters at the end of the file.  Delete those, and save it, and the problem should go away.
spindlespeed.m1s does actually have a syntax error in it, in some versions of Mach3, yet it does not always generate an error message.
« Reply #2 on: November 30, 2011, 11:37:01 AM »
Thanks that fixed the problem
« Reply #3 on: December 01, 2011, 11:05:15 AM »
Still getting Scripter Compile Error in M3.mis
Machine ran fine all day no problems, started this morning agin, checked files and everything looks normal but spindle does not turn,Requries mach reboot to fix
Any Ideas??
« Reply #4 on: December 01, 2011, 11:49:50 AM »
Any ideas
Problem continues
« Last Edit: December 01, 2011, 11:54:15 AM by egerber »
« Reply #5 on: December 01, 2011, 11:58:36 AM »
Any Ideas??
That, too, is, sadly, consistent with my experience.  I believe something is happening inside Mach3 that causes this, as the same script will throw an error one time, and not the next.  Sometimes editing the script will help, sometimes not.  I've got quite a number of conditions that pop up more or less randomly, that require re-starting Mach3 to restore proper operation.  It is my great frustration with Mach3 - I can go days at a time and everything will function perfectly, then I'll have a day where I have one bizarre problem after another, and I can't get any work done.
« Reply #6 on: December 01, 2011, 11:58:50 AM »
What version of mach3? I use an old version, and have never seen this error.
« Reply #7 on: December 01, 2011, 12:19:04 PM »
Gerry,
I couldn't tell you when this issue first cropped up, but it's been around a couple of years, since at least 3.042.022.  I'm now using 3.043.053, and have used dozens of intermediate versions.
« Reply #8 on: December 01, 2011, 03:12:35 PM »
Hiya Ray there is a reason that a lot of us stay at the 3.042.020 version or very close to it.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #9 on: December 01, 2011, 04:22:27 PM »
Ain't that the truth. I just can't understand why subsequent releases have been made without thorough beta testing. Personally I wouldn't go near them with a barge pole.
Ian
