Hello
Guest
it is
November 09, 2026, 02:59:20 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
PRO/E to Gcode
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: PRO/E to Gcode (Read 13594 times)
mcbooya
2
PRO/E to Gcode
on:
November 21, 2011, 03:22:14 PM »
Does anyone know of a way to take .ncl files that Pro/Engineer Manufacturing creates and convert them to work with Mach3 for a 3 axis router CNC? I am new to CNC machining so I am looking for a simple and easy to understand solution. Thanks
Logged
Carnoustie, Scotland
Re: PRO/E to Gcode
Reply #1 on:
November 21, 2011, 04:16:33 PM »
Afraid I dont know anything about Pro Engineer, what does the output code look like?
Logged
mcbooya
2
Re: PRO/E to Gcode
Reply #2 on:
November 21, 2011, 05:13:09 PM »
Attached is the output from PRO/E, but it is not Gcode that my cnc will accept. I would think that with how capable PRO/E is at making NC toolpaths that there must be an easy way to process it to Gcode automatically.
Logged
Re: PRO/E to Gcode
Reply #3 on:
November 21, 2011, 05:17:51 PM »
Certainly no use for Mach but you already know that
What exactly is Pro Engineer? Is it a CAM programme?
Logged
gqcarter
1
Re: PRO/E to Gcode
Reply #4 on:
December 23, 2011, 01:30:16 PM »
With Pro/MANUFACTURE you should have a copy of GPOST. You can use the HAAS post in GPOST to create a .tap file that Mach3 can use.
Logged
Print
Pages:
1
Go Up
« previous
next »
