May 21, 2013, 11:49:05 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  SmoothStepper USB (Moderator: Warp9TD)
| | |-+  Ethernet SmoothStepper first test
Pages: « 1 2 3 4 5 6 7 8 9 10 11 12 »   Go Down
Print
Author Topic: Ethernet SmoothStepper first test  (Read 14284 times)
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #50 on: January 23, 2012, 06:35:14 AM »
Yes, setting max axis KHz is just the same, also for controller frequency I would try at 2KHz first, maybe 4KHz will be fine, it is for me, but some people have reported occasional drop outs at the 4KHz.
trialanderror
Active Member
Offline Offline
View Profile
« Reply #51 on: January 23, 2012, 06:41:58 AM »
So I should be fine following the 2008 instructions for the USB mode for those settings yah? For now at least. Also I am running this on Windows 7 64Bit
Dan13
Active Member
Offline Offline
View Profile WWW
« Reply #52 on: January 23, 2012, 06:58:07 AM »
Hood,
Think you meant to say MHz for controller frequency Wink
Active Member
Offline Offline
View Profile
« Reply #53 on: January 23, 2012, 07:51:29 AM »
Hood,
No Dan I meant to say what I said Wink
« Last Edit: January 23, 2012, 07:54:57 AM by Hood » Logged
thosj
Active Member
Offline Offline
View Profile
« Reply #54 on: January 23, 2012, 08:00:16 AM »
The settings will be pretty much like the USB version, but be aware that the ONLY SS doc out there is very old and the screen doesn't even LOOK like the screenshot in the doc any more!!
You will definately be able to get help here or on Warp9td if necessary.
Dan13
Active Member
Offline Offline
View Profile WWW
« Reply #55 on: January 23, 2012, 09:26:26 AM »
Sorry, Hood. Confused it with axis frequency.
Active Member
Offline Offline
View Profile
« Reply #56 on: January 23, 2012, 09:36:21 AM »
No probs Dan, wouldnt be the first time I was wrong but, unusually, on this occasion I was right Grin
While you are here, any news on the new rev of Dolphin?
Dan13
Active Member
Offline Offline
View Profile WWW
« Reply #57 on: January 23, 2012, 09:42:49 AM »
No. No news since the last time, Hood Sad
Active Member
Offline Offline
View Profile
« Reply #58 on: January 23, 2012, 09:45:51 AM »
Ok was just wondering as they were sending me out a demo of it in a couple of weeks they said, its been over a month  and I have not got it. Sounds like their time is set on programmers time Grin
Dan13
Active Member
Offline Offline
View Profile WWW
« Reply #59 on: January 23, 2012, 09:57:50 AM »
Yes. Looks so Cheesy Usual time terms often don't work for R&D.
Pages: « 1 2 3 4 5 6 7 8 9 10 11 12 »   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
