Hello
Guest
it is
April 24, 2024, 05:55:53 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Eagle & pcb-gcode help
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Eagle & pcb-gcode help (Read 6278 times)
michel-cnc
16
on:
November 12, 2011, 06:54:17 AM »
Hello !
I have tried Eagle & pcb-gcode following example at
http://www.instructables.com/id/Turn-your-EAGLE-schematic-into-a-PCB/
I have generated the G-code and have a look to the result given by pcb-gcode and i can see problems with the toolpath generation:
there are some shortcuts !!
You can have a look to the joined files: i put a screen copy of the settings in pcg-gcode (it runs under eagle) and the result.
If somebody have some hints, they are welcomed !
Tweakie.CNC
9,199
Super Kitty
Re: Eagle & pcb-gcode help
Reply #1 on:
November 12, 2011, 11:07:12 AM »
Looks like you have lots of errors on that PCB.
Mach cannot help resolve those issues, the GCode needs to be right before Mach becomes involved.
The only thing I can suggest is that you practice using Eagle and PCB-GCode a bit more or perhaps ask some questions at the Eagle forum
http://www.cadsoftusa.com/forums/guidelines/?language=en
Not much help really, sorry.
Grafix
18
Reply #2 on:
December 30, 2011, 06:26:50 PM »
Its also quite possible that the gap is too small for the cutter that you specified. ie, the gaps 1mm and the cutter is 1.5mm.
Print
Pages:
1
Go Up
« previous
next »
