Welcome, Guest. Please login or register.
Did you miss your activation email?
May 26, 2013, 03:05:13 AM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  G-Code, CAD, and CAM
| |-+  G-Code, CAD, and CAM discussions
| | |-+  Eagle & pcb-gcode help
Pages: 1   Go Down
Print
Author Topic: Eagle & pcb-gcode help  (Read 1087 times)
michel-cnc
Active Member
Offline Offline
View Profile
« on: November 12, 2011, 06:54:17 AM »
Hello !
I have tried Eagle & pcb-gcode following example at
http://www.instructables.com/id/Turn-your-EAGLE-schematic-into-a-PCB/
I have generated the G-code and have a look to the result given by pcb-gcode and i can see problems with the toolpath generation:
there are some shortcuts !!
You can have a look to the joined files: i put a screen copy of the settings in pcg-gcode (it runs under eagle) and the result.
If somebody have some hints, they are welcomed !
Logged
Tweakie.CNC
Global Moderator
Offline Offline
Super Kitty.
View Profile WWW
« Reply #1 on: November 12, 2011, 11:07:12 AM »
Looks like you have lots of errors on that PCB.
Mach cannot help resolve those issues, the GCode needs to be right before Mach becomes involved.
The only thing I can suggest is that you practice using Eagle and PCB-GCode a bit more or perhaps ask some questions at the Eagle forum http://www.cadsoftusa.com/forums/guidelines/?language=en
Not much help really, sorry.
Logged
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Grafix
Active Member
Offline Offline
View Profile
« Reply #2 on: December 30, 2011, 06:26:50 PM »
Its also quite possible that the gap is too small for the cutter that you specified. ie, the gaps 1mm and the cutter is 1.5mm.
Logged
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
