Hello Guest it is April 15, 2026, 04:12:25 AM
Author Topic: New ShuttleRU pendant plugins available.  (Read 8883 times)
« on: November 02, 2011, 12:53:09 PM »
After reading about the shuttleRU here:
http://www.cnczone.com/forums/mach_software_artsoft_software/113193-usb_pendant_russia.html
I purchased Andrey's fabulous ShuttleRU with the LCD screen a few weeks ago. Overall it was VERY well built and had nice paint job as well.
The unit had some odd behavior in that when rotating the inner wheel, phantom button presses would occasionally occur after many full revolutions. I asked for the plugin source code which he sent me to see if I could get to the bottom to this. This problem has been fixed, and I also added several new features. You can download the new plugin from his website here:
http://cncpendant.ru/en/download.html
Be sure to get the v.6 plugins, not the older ones listed at the top of the window. To install, simply delete the existing Shuttle plugin, and unzip both files from the download into the c:\mach3\plugins folder. The .dll is the plugin itself, and the .xml file is the source file for the popup tips I implemented for the button function selection.
