Pulled off the remaining sections of the Y way covers, the last owner indicated repair work on the trust bearing. Moving things by hand, I can not feel any backlash, so I am optimistic it has been repaired. When it’s up and running under Mach control, I’ll check it completely out. The Y ways and ball screw look good, big and beefy too.
Pulled the cover off the ATC, it needs some lube on the ram. 24 tools will be great to have !
JH
