Hello Guest it is March 28, 2024, 07:54:56 PM
Author Topic: Spindle speed display at all times.  (Read 3903 times)
« on: August 29, 2011, 04:26:02 PM »
In Mach3Turn currently the spindle speed display only works when the spindle relays are enabled and the spindle is turned on.
since I am not using the relay and it is possible for my spindle to be turning even when mach has not commanded it to
would it be possible to change this so that spindle speed is always displayed, whatever the commanded state.
Re: Spindle speed display at all times.
« Reply #1 on: October 10, 2011, 04:06:18 PM »
YOu would have to back up a ways in versions to have that function. That I am aware of NO it cannot be changed in the later versions.
