Hello Guest it is April 26, 2024, 09:32:03 PM
Author Topic: Foam 2D with X Y Z A hot wire  (Read 8478 times)
« on: August 16, 2011, 07:58:57 AM »
Hi:
My machine is X horiz right, Y vert right, Z vert left and A horiz left. I don´t have B, C, etc. Usually I cut wings in 3D with Profili soft, which generates GCodes I cut via Mach3.
Sometimes I need to cut 2D profils designed in Acad in dxf. Lazy Cam only generates GCode with X and Y axes (with default pre processors) so in Mach3 I define A axis (horiz left) as salve of X (horiz right) but I can´t define Z (vert left) as slave of Y (vert right) because Z is main axe. I think I´m right.
Is it possible with Lazycam, generating a GCode with XYZA axis? X and A would be identical, and the same with Y and Z. ¿Perhaps with a foam 2D specific post processor?.
Thanks.
Edu
Re: Foam 2D with X Y Z A hot wire
« Reply #1 on: August 16, 2011, 05:40:09 PM »
Edu,
Lazycam is the way it is and is no longer being developed so your on your owne.
Don't have the foggiest idea on how to change LC's post processor.
« Reply #2 on: August 16, 2011, 06:23:17 PM »
Might want to reconsider your axis assignments it would make it easier to deal with.  X/a Y/b
(;-) tp
« Reply #3 on: August 16, 2011, 06:32:24 PM »
(;-) tp
My board has only X,Y,Z,A :(
« Reply #4 on: August 16, 2011, 06:43:53 PM »
It does not matter what the board thinks they are. You make the axis assignments and slaving in MAch3 config pins/ports and slave axis settings
« Last Edit: August 16, 2011, 06:49:40 PM by BR549 »
« Reply #5 on: August 18, 2011, 03:22:40 AM »
Thank you very much. I've got it as you said, BR549  :)
« Reply #6 on: October 13, 2011, 12:49:52 PM »
ive got the exact same problem but dont have a clue how to change the pins ports, or rather what to change them too ?
« Reply #7 on: October 13, 2011, 12:59:06 PM »
In pin assignments screen, Z line in blank, and what was there, write it in B line. Now you´ll have B axis and it will be able to slave to Y axis
« Reply #8 on: October 13, 2011, 02:16:19 PM »
thank you, going to have a crack at it now
« Reply #9 on: October 13, 2011, 03:34:46 PM »
it works, thanks :D
