Hello Guest it is April 23, 2024, 02:28:15 AM
Author Topic: New (revised) Mach3 6-axis screen  (Read 58069 times)
Re: New (revised) Mach3 6-axis screen
« Reply #20 on: March 21, 2012, 07:53:11 AM »
Hii All
Am following the 6 axis screen topic with interest as I need a good working one for my 5 axis mill , firstly how do you make a screen is there a tutorial or document to explain the procedure and i notice on the 'Darc' download screen the manual jog panel only has 4 axis displayed. I would like to fix a few of these things myself just need the how to document.
Clive
« Reply #21 on: March 21, 2012, 08:14:52 PM »
There are tutorials in the Support > Tutorial Videos section. Look for the Screen 4 video(s).
« Reply #22 on: January 27, 2014, 01:18:09 PM »
hi i downloaded the screen set and installed it and it looks like the image but when i run a g code in the MDI menue the axes value dont change and still at zero position , can you please help me with that and tell me what version of mach 3 is should use because im making a cnc machine as a graduation project
« Reply #23 on: January 27, 2014, 01:42:42 PM »
You need to setup the motor ports and pins before the DRO's will show any movement.
« Reply #24 on: January 27, 2014, 01:55:01 PM »
thank you very much gerry it works fine now
« Reply #25 on: May 05, 2016, 08:37:11 AM »
I have downloaded the 6Axis screenset but it is not showing all buttons on my computer, what do I need to do.
« Reply #26 on: January 12, 2017, 12:37:12 PM »
Hello,
I have the same problem as Jimalo has. Not sure why though. All the buttons appear to be working when clicked upon, they are just not visible.
I have downloaded the latest GPU drivers as that was my first idea but this did not help.
Also once I changed the PC screen resolution and the icons appeared but was unable to replicate this :(
I am attaching the screenshot of the Mach3 screen.
Any help is appreciated.
Thank you.
BR,
Hydrant
  •  9,199 9,199
« Reply #27 on: January 13, 2017, 01:47:45 AM »
When you download and install a new screen you also need to copy it's associated graphics to the Mach3 Bitmaps folder.
« Reply #28 on: January 13, 2017, 08:34:32 AM »
Hello Tweakie,
Oh, thank you. That worked.
First time I copied it to wrong folder apparently.
Thank you very much for your help.
BR,
Hydrant
