Hello Guest it is April 25, 2024, 05:52:10 PM
Author Topic: Machcloud file extension question  (Read 16897 times)
Re: Machcloud file extension question
« Reply #10 on: July 29, 2011, 09:38:51 PM »
The pointfile  is raw data it must be converted to a MESH with machcloud.  That will results in a STL file.  Next the STL has to read into a program that can convert it to a Soild then dxf or straight to Gcode.
Not every Cad can handle the STL format directly. DOn't know if your version of Acad can or not. (;-)
« Reply #11 on: February 18, 2014, 02:33:51 AM »
Not correct sorry, when you go to remove the "a" cords instead replace them with a space then " line" then under edit select all then copy.
In Autocad type line then paste the file into the command line. This will enter the cords and the line command till it draws the file.
Same thing thow no letters just comma's.
Steve
I have this ultimate set of tools I can fix it.
