Hello Guest it is June 10, 2026, 01:19:28 AM
Poll
Does your computer remain slow when Mach has closed down?
YES
5 (22.7%)
NO
17 (77.3%)
Total Members Voted: 18
Author Topic: Does your computer remain slow when Mach has closed down?  (Read 214136 times)
ynneb
« on: December 05, 2006, 07:00:25 PM »
I have run Mach on a few different computers, and it seems to bog down the computer even when it has been shut down.
The only computer that it didnt do this to, has an Intell chip, all the others were AMD.
Does your computer run slow until it is rebooted ?
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
Re: Does your computer remain slow when Mach has closed down?
« Reply #1 on: December 05, 2006, 09:04:43 PM »
Hi Benny, Is it just the mouse, video or is it everything?
Chad
ynneb
« Reply #2 on: December 05, 2006, 10:14:29 PM »
Programs take ages to open. Basically it become sluggish in most areas.
This has not been a problem because I use a computer that just runs Mach to drive the machine.
However when I power up mach on my home use computer to test things, it does become a problem when I want to then use other software afterwards.
« Reply #3 on: December 05, 2006, 10:59:14 PM »
Hey Benny,
     I noticed this in the past if I installed the drivers. This was on my office PC. I actually replaced the hard drive once. A friend of mine told me of the problem. He said once he loaded Mach his PC got slower and slower, thought he was fixing to have some serious problems. He removed the Mach drivers and it fixed him up. This may all be coincident but I don't install the drivers on the office PC anymore. Did you install the drivers?
« Reply #4 on: December 07, 2006, 09:16:12 PM »
I have AMD 3200 Athalon with XP and also Intel P3 1Ghz win2k and not had any issues with Mach 3 shut down - all versions. I have laptop Intel Centrino and didn't install the drivers so not sure about that.
Had lots of hang-ups before I found the Mach3 inputs config had a random reference to Port 2 that was not enabled - kept crashing when the mouse was moved! Took months to find!
When your computer is slow, use Ctl Alt Del, select task manager and processes and see if Mach3 is still running - and CPU usage? Might help see what is going on.
By the way, did you optimise running processes? XP, I did not, Win 2k I did - helped a lot with performance but take care...
Offline mikee
  •  100 100
« Reply #5 on: June 19, 2011, 09:31:28 PM »
 YES  slowed everything down
   my office pc
crashed just moving my mouse couldnt close any window or even power down pc
  adobe downloads and drive or driver wizards  when it seem to start or i thought somthing was not right
 but i was down loading mach 3 and cam bam all at the same time  watching every video on mach3 and cam bam i could find
what worked for me  called a friend he came over  told me
  i was at my max on the memory no memory space left
replace rams with twice the memory
pc had never been defrag  ran ultimate defrag c drive was a mess
ran defender pro 2011 5 in 1  (scary) pc went blue screen for 4 hr
 pc runs just like it did when it was new (2006)  very fast
 i can see now how i need to learn about pc and spec
i did install the rams myself. first time working on a pc
moving windows XP  pc into shop and will replace office pc
 with a dell with windows vista  i have never ran vista windows
 happy fathers day
