Hello Guest it is March 28, 2024, 05:55:36 PM
Author Topic: Automatic G-Code Generation – with Scripts to Generate Part Models in SketchUp  (Read 3737 times)
We are happy to announce the availability of a new program to generate g-code automatically for woodworking joints.  The program being released now is a free demonstration program to generate g-code for mortises.  A complete g-code program can be generated in 2 minutes or less by simply entering parameters for stock size, mortise size and placement, feed rates, etc.
In the near future a full version of the program will be available at a reasonable cost.  The full version will generate a variety of woodworking joints such as dados, tenons, dovetails and hinge pockets.
In addition to generating g code, plugins are available for Google SketchUp which will automatically generate the part in SketchUp.
This approach is backwards from the standard process of designing in a CAD package, exporting to a CAM package, then generating a g-code file.  Our claim is that our method will save you considerable time, since you need only enter a handful of parameters and some standard text.  Admittedly, these cuts are all relatively simple, but they are also the foundation for furniture and cabinet building.
The program – CambumCode Free – is available for download at www.cambiummachines.com\Gcode.html
You may also be interested in out tool for setting up CNC routers running on Mach3, which is available at www.cambiummachines.com\Setup.html
