Hello Guest it is May 08, 2024, 02:05:01 PM
Author Topic: New Win7 install not connecting  (Read 12235 times)
Re: New Win7 install not connecting
« Reply #10 on: August 15, 2015, 09:16:10 PM »
I am having an issue with HP, Win 7 Pro, and Mach4, DSPMC . I originally put together Mach4 , DSPMC, with Win 8.1 on Lenovo Y50-70 Laptop , this was a flawless setup as far as networking was concerned, I had zero issues. NOW, with HP windows 7 Pro, and even an added additional NIC, I cannot get a consistent connection. Yes I tried various IP configurations, windows firewall disable, ect, ect, The onboard NIC proved to be a potential problem, so I went out and bought another NIC by TP-Link, At least I get a connection to VSI, and DSPMC now, but it will not enable my system , nor will it stay connected for more than 10 seconds, it times out. I can see the encoders moving, and the values in the DRO will move along with manual movement. My enable circuit will not enable on the 7535 PNP, and a big red LED on the dspmc. Ive tried updating the driver of the NIC, and rebooted everything various times to rid of error on DSPMC. If I connect my lenovo back to the dspmc, everything is fine.
Not really sure what to do at this point. I have never really run into a networking issue I couldnt resolve. I suspect its to do with WIN 7 PRO software related. I did notice that Ive got quite a few more driver setting options in my Lenovo NIC than either of the ones on this HP. The VSI detects the the DSPMC, and Mach4 Detects DSPMC.
Thanks for any help in advance
DSPMC Plugin: 1.08.06, Target_Mach4_Build: 2491, Board: 7762, Serial: BF3077, FW: 8.38, FPGA: E901, IP: 192.168.0.50, AdapterIP: 192.168.0.10
ERROR: DAC Watchdog Triggered. Check if encoder polarity matches axis direction
ERROR: DSPMC disconnected
ERROR: Connection to DSPMC has timed out...
ERROR: No DSPMC connection present.
DSPMC Plugin: 1.08.06, Target_Mach4_Build: 2491, Board: 7762, Serial: BF3077, FW: 8.38, FPGA: E901, IP: 192.168.0.50, AdapterIP: 192.168.0.10ERROR: Disarmed Drives unexpectedly.  Please do not run any other software on this computer while Mach is controlling the millSystem Arm ErrorERROR: DSPMC disconnectedERROR: Connection to DSPMC has timed out...DSPMC Plugin: 1.08.06, Target_Mach4_Build: 2491, Board: 7762, Serial: BF3077, FW: 8.38, FPGA: E901, IP: 192.168.0.50, AdapterIP: 192.168.0.10ERROR: DSPMC disconnectedERROR: No DSPMC connection present.ERROR: Connection to DSPMC has timed out...DSPMC Plugin: 1.08.06, Target_Mach4_Build: 2491, Board: 7762, Serial: BF3077, FW: 8.38, FPGA: E901, IP: 192.168.0.50, AdapterIP: 192.168.0.10ERROR: DSPMC disconnectedERROR: Connection to DSPMC has timed out...DSPMC Plugin: 1.08.06, Target_Mach4_Build: 2491, Board: 7762, Serial: BF3077, FW: 8.38, FPGA: E901, IP: 192.168.0.50, AdapterIP: 192.168.0.10ERROR: DSPMC disconnectedERROR: No DSPMC connection present.ERROR: Connection to DSPMC has timed out...DSPMC Plugin: 1.08.06, Target_Mach4_Build: 2491, Board: 7762, Serial: BF3077, FW: 8.38, FPGA: E901, IP: 192.168.0.50, AdapterIP: 192.168.0.10ERROR: DSPMC disconnectedERROR: Connection to DSPMC has timed out...DSPMC Plugin: 1.08.06, Target_Mach4_Build: 2491, Board: 7762, Serial: BF3077, FW: 8.38, FPGA: E901, IP: 192.168.0.50, AdapterIP: 192.168.0.10ERROR: DSPMC disconnectedERROR: No DSPMC connection present.ERROR: Connection to DSPMC has timed out...DSPMC Plugin: 1.08.06, Target_Mach4_Build: 2491, Board: 7762, Serial: BF3077, FW: 8.38, FPGA: E901, IP: 192.168.0.50, AdapterIP: 192.168.0.10ERROR: DSPMC disconnectedERROR: Connection to DSPMC has timed out...DSPMC Plugin: 1.08.06, Target_Mach4_Build: 2491, Board: 7762, Serial: BF3077, FW: 8.38, FPGA: E901, IP: 192.168.0.50, AdapterIP: 192.168.0.10ERROR: DSPMC disconnectedERROR: No DSPMC connection present.ERROR: Connection to DSPMC has timed out...DSPMC Plugin: 1.08.06, Target_Mach4_Build: 2491, Board: 7762, Serial: BF3077, FW: 8.38, FPGA: E901, IP: 192.168.0.50, AdapterIP: 192.168.0.10ERROR: DSPMC disconnectedERROR: Connection to DSPMC has timed out...DSPMC Plugin: 1.08.06, Target_Mach4_Build: 2491, Board: 7762, Serial: BF3077, FW: 8.38, FPGA: E901, IP: 192.168.0.50, AdapterIP: 192.168.0.10
2015-08-15 17:10:50.825 - Loggging Enabled.
2015-08-15 17:10:56.741 - API: mcCntlEnable(false) called.
2015-08-15 17:10:56.742 - Signal id 1019, (Enable #1), changed from HIGH to LOW.
2015-08-15 17:10:56.742 - Signal id 1020, (Enable #2), changed from HIGH to LOW.
2015-08-15 17:10:56.743 - Signal id 1018, (Enable #0), changed from HIGH to LOW.
2015-08-15 17:10:56.743 - Signal id 1120, (Machine Enabled), changed from HIGH to LOW.
2015-08-15 17:10:56.743 - API: mcCntlEnable(false) called.
2015-08-15 17:10:57.243 - API: mcCntlEnable(false) called.
2015-08-15 17:10:59.272 - API: mcCntlEnable(false) called.
2015-08-15 17:10:59.330 - API: mcCntlEnable(false) called.
2015-08-15 17:10:59.495 - API: mcAxisDerefAll()
2015-08-15 17:10:59.495 - API: mcAxisDeref() called. axis 0
2015-08-15 17:10:59.495 - API: mcAxisDeref() called. axis 1
2015-08-15 17:10:59.495 - API: mcAxisDeref() called. axis 2
2015-08-15 17:10:59.495 - API: mcAxisDeref() called. axis 3
2015-08-15 17:10:59.495 - API: mcAxisDeref() called. axis 4
2015-08-15 17:10:59.495 - API: mcAxisDeref() called. axis 5
2015-08-15 17:10:59.495 - API: mcAxisDeref() called. axis 6
2015-08-15 17:10:59.495 - API: mcAxisDeref() called. axis 7
2015-08-15 17:10:59.495 - API: mcAxisDeref() called. axis 8
2015-08-15 17:10:59.495 - API: mcAxisDeref() called. axis 9
2015-08-15 17:10:59.495 - API: mcAxisDeref() called. axis 10
2015-08-15 17:10:59.495 - API: mcAxisDeref() called. axis 11
2015-08-15 17:11:00.012 - API: mcMotionSync() called.
2015-08-15 17:11:00.012 - SyncPosition()!
2015-08-15 17:11:09.367 - API: mcCntlEnable(false) called.
2015-08-15 17:11:09.870 - API: mcCntlEnable(false) called.
2015-08-15 17:11:11.901 - API: mcCntlEnable(false) called.
2015-08-15 17:11:12.020 - API: mcAxisDerefAll()
2015-08-15 17:11:12.020 - API: mcAxisDeref() called. axis 0
2015-08-15 17:11:12.020 - API: mcAxisDeref() called. axis 1
2015-08-15 17:11:12.020 - API: mcAxisDeref() called. axis 2
2015-08-15 17:11:12.020 - API: mcAxisDeref() called. axis 3
2015-08-15 17:11:12.020 - API: mcAxisDeref() called. axis 4
2015-08-15 17:11:12.020 - API: mcAxisDeref() called. axis 5
2015-08-15 17:11:12.020 - API: mcAxisDeref() called. axis 6
2015-08-15 17:11:12.020 - API: mcAxisDeref() called. axis 7
2015-08-15 17:11:12.020 - API: mcAxisDeref() called. axis 8
2015-08-15 17:11:12.020 - API: mcAxisDeref() called. axis 9
2015-08-15 17:11:12.020 - API: mcAxisDeref() called. axis 10
2015-08-15 17:11:12.020 - API: mcAxisDeref() called. axis 11
2015-08-15 17:11:12.537 - API: mcMotionSync() called.
2015-08-15 17:11:12.537 - SyncPosition()!
2015-08-15 17:11:18.590 - Signal id 1120, (Machine Enabled), changed from LOW to HIGH.
2015-08-15 17:11:18.591 - API: mcCntlEnable(true) called.
2015-08-15 17:11:18.592 - Signal id 1019, (Enable #1), changed from LOW to HIGH.
2015-08-15 17:11:18.592 - Signal id 1020, (Enable #2), changed from LOW to HIGH.
2015-08-15 17:11:18.593 - Signal id 1018, (Enable #0), changed from LOW to HIGH.
2015-08-15 17:11:18.594 - API: mcMotionClearPlanner() called.
2015-08-15 17:11:18.594 - API: mcMotionSync() called.
2015-08-15 17:11:18.594 - SyncPosition()!
2015-08-15 17:11:18.595 - API: mcMotionSetThreadingRate() called.Ratio 1.2000
2015-08-15 17:11:28.621 - API: mcCntlEnable(false) called.
2015-08-15 17:11:28.622 - Signal id 1019, (Enable #1), changed from HIGH to LOW.
2015-08-15 17:11:28.623 - Signal id 1020, (Enable #2), changed from HIGH to LOW.
2015-08-15 17:11:28.623 - Signal id 1018, (Enable #0), changed from HIGH to LOW.
2015-08-15 17:11:28.624 - Signal id 1120, (Machine Enabled), changed from HIGH to LOW.
2015-08-15 17:11:28.624 - API: mcCntlEnable(false) called.
2015-08-15 17:11:29.123 - API: mcCntlEnable(false) called.
2015-08-15 17:11:31.153 - API: mcCntlEnable(false) called.
2015-08-15 17:11:31.212 - API: mcCntlEnable(false) called.
2015-08-15 17:11:31.376 - API: mcAxisDerefAll()
2015-08-15 17:11:31.376 - API: mcAxisDeref() called. axis 0
2015-08-15 17:11:31.376 - API: mcAxisDeref() called. axis 1
2015-08-15 17:11:31.376 - API: mcAxisDeref() called. axis 2
2015-08-15 17:11:31.376 - API: mcAxisDeref() called. axis 3
2015-08-15 17:11:31.376 - API: mcAxisDeref() called. axis 4
2015-08-15 17:11:31.376 - API: mcAxisDeref() called. axis 5
2015-08-15 17:11:31.376 - API: mcAxisDeref() called. axis 6
2015-08-15 17:11:31.376 - API: mcAxisDeref() called. axis 7
2015-08-15 17:11:31.376 - API: mcAxisDeref() called. axis 8
2015-08-15 17:11:31.376 - API: mcAxisDeref() called. axis 9
2015-08-15 17:11:31.376 - API: mcAxisDeref() called. axis 10
2015-08-15 17:11:31.376 - API: mcAxisDeref() called. axis 11
2015-08-15 17:11:31.892 - API: mcMotionSync() called.
2015-08-15 17:11:31.892 - SyncPosition()!
2015-08-15 17:11:41.248 - API: mcCntlEnable(false) called.
2015-08-15 17:11:41.750 - API: mcCntlEnable(false) called.
2015-08-15 17:11:43.779 - API: mcCntlEnable(false) called.
2015-08-15 17:11:43.897 - API: mcAxisDerefAll()
2015-08-15 17:11:43.897 - API: mcAxisDeref() called. axis 0
2015-08-15 17:11:43.897 - API: mcAxisDeref() called. axis 1
2015-08-15 17:11:43.897 - API: mcAxisDeref() called. axis 2
2015-08-15 17:11:43.897 - API: mcAxisDeref() called. axis 3
2015-08-15 17:11:43.897 - API: mcAxisDeref() called. axis 4
2015-08-15 17:11:43.897 - API: mcAxisDeref() called. axis 5
2015-08-15 17:11:43.897 - API: mcAxisDeref() called. axis 6
2015-08-15 17:11:43.897 - API: mcAxisDeref() called. axis 7
2015-08-15 17:11:43.897 - API: mcAxisDeref() called. axis 8
2015-08-15 17:11:43.897 - API: mcAxisDeref() called. axis 9
2015-08-15 17:11:43.897 - API: mcAxisDeref() called. axis 10
2015-08-15 17:11:43.897 - API: mcAxisDeref() called. axis 11
2015-08-15 17:11:44.414 - API: mcMotionSync() called.
2015-08-15 17:11:44.414 - SyncPosition()!
2015-08-15 17:12:28.036 - Signal id 1120, (Machine Enabled), changed from LOW to HIGH.
2015-08-15 17:12:28.036 - API: mcCntlEnable(true) called.
2015-08-15 17:12:28.037 - Signal id 1019, (Enable #1), changed from LOW to HIGH.
2015-08-15 17:12:28.038 - Signal id 1020, (Enable #2), changed from LOW to HIGH.
2015-08-15 17:12:28.038 - Signal id 1018, (Enable #0), changed from LOW to HIGH.
2015-08-15 17:12:28.039 - API: mcMotionClearPlanner() called.
2015-08-15 17:12:28.039 - API: mcMotionSync() called.
2015-08-15 17:12:28.039 - SyncPosition()!
2015-08-15 17:12:28.039 - API: mcMotionSetThreadingRate() called.Ratio 1.2000
2015-08-15 17:12:38.069 - API: mcCntlEnable(false) called.
2015-08-15 17:12:38.070 - Signal id 1019, (Enable #1), changed from HIGH to LOW.
2015-08-15 17:12:38.070 - Signal id 1020, (Enable #2), changed from HIGH to LOW.
2015-08-15 17:12:38.071 - Signal id 1018, (Enable #0), changed from HIGH to LOW.
2015-08-15 17:12:38.071 - Signal id 1120, (Machine Enabled), changed from HIGH to LOW.
2015-08-15 17:12:38.071 - API: mcCntlEnable(false) called.
2015-08-15 17:12:38.571 - API: mcCntlEnable(false) called.
2015-08-15 17:12:40.600 - API: mcCntlEnable(false) called.
2015-08-15 17:12:40.659 - API: mcCntlEnable(false) called.
2015-08-15 17:12:40.823 - API: mcAxisDerefAll()
2015-08-15 17:12:40.823 - API: mcAxisDeref() called. axis 0
2015-08-15 17:12:40.823 - API: mcAxisDeref() called. axis 1
2015-08-15 17:12:40.823 - API: mcAxisDeref() called. axis 2
2015-08-15 17:12:40.823 - API: mcAxisDeref() called. axis 3
2015-08-15 17:12:40.823 - API: mcAxisDeref() called. axis 4
2015-08-15 17:12:40.823 - API: mcAxisDeref() called. axis 5
2015-08-15 17:12:40.823 - API: mcAxisDeref() called. axis 6
2015-08-15 17:12:40.823 - API: mcAxisDeref() called. axis 7
2015-08-15 17:12:40.823 - API: mcAxisDeref() called. axis 8
2015-08-15 17:12:40.823 - API: mcAxisDeref() called. axis 9
2015-08-15 17:12:40.823 - API: mcAxisDeref() called. axis 10
2015-08-15 17:12:40.823 - API: mcAxisDeref() called. axis 11
2015-08-15 17:12:41.340 - API: mcMotionSync() called.
2015-08-15 17:12:41.340 - SyncPosition()!
2015-08-15 17:12:50.695 - API: mcCntlEnable(false) called.
2015-08-15 17:12:51.197 - API: mcCntlEnable(false) called.
2015-08-15 17:12:53.227 - API: mcCntlEnable(false) called.
2015-08-15 17:12:53.346 - API: mcAxisDerefAll()
2015-08-15 17:12:53.346 - API: mcAxisDeref() called. axis 0
2015-08-15 17:12:53.346 - API: mcAxisDeref() called. axis 1
2015-08-15 17:12:53.346 - API: mcAxisDeref() called. axis 2
2015-08-15 17:12:53.346 - API: mcAxisDeref() called. axis 3
2015-08-15 17:12:53.346 - API: mcAxisDeref() called. axis 4
2015-08-15 17:12:53.346 - API: mcAxisDeref() called. axis 5
2015-08-15 17:12:53.346 - API: mcAxisDeref() called. axis 6
2015-08-15 17:12:53.346 - API: mcAxisDeref() called. axis 7
2015-08-15 17:12:53.346 - API: mcAxisDeref() called. axis 8
2015-08-15 17:12:53.346 - API: mcAxisDeref() called. axis 9
2015-08-15 17:12:53.346 - API: mcAxisDeref() called. axis 10
2015-08-15 17:12:53.346 - API: mcAxisDeref() called. axis 11
2015-08-15 17:12:53.862 - API: mcMotionSync() called.
2015-08-15 17:12:53.862 - SyncPosition()!
« Reply #11 on: August 15, 2015, 09:45:19 PM »
Nevermind, for some reason, a firmware update from VSI fixed the problem
