Hello Guest it is April 27, 2024, 12:56:52 AM
Author Topic: Changing Demension  (Read 4393 times)
Offline BLA
  •  1 1
Changing Demension
« on: June 06, 2011, 10:02:04 PM »
I am new to mach3 and using a licensed version and having a problem I can't figure out. I have a simple part program to run and the first time I loaded the code and ran it the part size was correct. When I moved my zero over the run it again the part comes out smaller, and each time afterward it will be the smaller size. This has happened a few times now and I can't figure out what I'm doing to cause this. Any ideas? Thanks in advance.
