Hello Guest it is April 26, 2024, 07:49:06 AM
Author Topic: Demo Gcode  (Read 206751 times)
Re: Demo Gcode
« Reply #10 on: February 18, 2013, 06:59:13 PM »
I am having trouble downloading the files on a Vista desktop.
Please help
Re: Demo Gcode
« Reply #11 on: February 18, 2013, 07:09:20 PM »
Welcome to the forum pramodkotwal.  What kind of troubles are you having?
Re: Demo Gcode
« Reply #12 on: February 18, 2013, 07:29:08 PM »
When I click on the download tab on the web page, nothing happens.
What should I do ?
Is this a server issue ?
Re: Demo Gcode
« Reply #13 on: February 18, 2013, 08:11:24 PM »
It's downloading fine here.  You must have some restricitons on your PC that will not let you download.
Offline jeep534
  •  123 123
  • From the hills of WV
Re: Demo Gcode
« Reply #14 on: February 25, 2013, 10:20:02 AM »
not sure if this is under the limit (your mileage may very)
http://www.cad2gcode.com/cncprojects/id14.html
archie =) =) =)
Facebook archies machine
Re: Demo Gcode
« Reply #15 on: February 25, 2013, 10:35:56 AM »
Thanks Archie!
  •  9,200 9,200
Re: Demo Gcode
« Reply #16 on: March 31, 2013, 04:04:58 AM »
Bit of an educational project here with more details in this thread http://www.machsupport.com/forum/index.php/topic,24021.0.html
The material I used was 1.5mm thick polycarbonate. I have kept the feed-rate low but you may want to increase this using the FRO slider. The overall size can be scaled, if you wish, by using the X & Y axis scale DRO’s.
This tool-path has been created for use with a 2mm diameter end-mill with the X and Y zero (datum point) centre of the stock and Z zero with the tool touching the stock surface.
« Last Edit: January 08, 2017, 04:19:12 AM by Tweakie.CNC »
Re: Demo Gcode
« Reply #17 on: April 19, 2014, 03:43:53 AM »
Thank you for the demos , I have had my cnc for a week and have been trying to get my head around G code so I can see if it works.
Regards.
Leighton
  •  9,200 9,200
Re: Demo Gcode
« Reply #18 on: January 10, 2017, 01:55:40 AM »
Hi Guys,
Over the last weekend, I have added a few more Gcode files to the .zip folder in post #1 of this thread and I will add more Gcode files as they become available.
I have never had any problems running Imperial Unit Gcode programs on my Metric machines and I assume the same applies in reverse, provided the Gcode contains a G20 or G21 ( as appropriate). However, Graham Waterworth has written an excellent and very useful little program that can be used to scale / convert Gcode from Imperial to Metric or Metric to Imperial. This thread refers; http://www.machsupport.com/forum/index.php/topic,2893.0.html
It is usual to have the Gcode origin (X0, Y0) at the bottom left hand corner of the workpiece but for different reasons we may each prefer to have our Gcode origin in a different location. There is an excellent FREE software program available from Scorch Works which will re-calculate Gcode to move the origin to one of many different locations. This software can also be used as a backplotter converting Gcode to a .dxf and also a number of other functions are available. It can be downloaded from here; http://www.scorchworks.com/Gcoderipper/gcoderipper.html
  •  9,200 9,200
Re: Demo Gcode
« Reply #19 on: January 10, 2017, 02:19:29 AM »
This outline engraving of a young colt was downloaded as a FREE silhouette from http://vectorink.com/ and the Gcode created with Vectric Aspire. The Gcode file has now been added to the .zip folder.
« Last Edit: June 10, 2017, 06:48:19 AM by Tweakie.CNC »
