Hello
Guest
it is
April 24, 2024, 03:57:13 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
Newfangled Solutions Mach3 Wizards
(Moderator:
Ron Ginger
NEWFANGLED SOLUTIONS SOFTWARE - LATEST VERSION
« previous
next »
Print
Pages:
1
2
3
4
5
6
Go Down
Author
Topic: NEWFANGLED SOLUTIONS SOFTWARE - LATEST VERSION (Read 60550 times)
Kenneth
279
Re: NEWFANGLED SOLUTIONS SOFTWARE - LATEST VERSION
Reply #20 on:
March 06, 2013, 01:54:22 PM »
any chance to get a radius option in the rec pocket wizard?
would ask user for corner radii.
Logged
Kenneth
BR549
6,965
Reply #21 on:
March 06, 2013, 02:22:13 PM »
IF you are asking about the NFW Wizard "Rec Pocket" it DOES have the Corner radius feature.
Just a thought, (;-) TP
Logged
Kenneth
279
Reply #22 on:
March 06, 2013, 02:32:30 PM »
yes i was. but is it the purchased version or the default.
i have mach3 Version R3.043.066. and i can't see where to add a radius.
i looked in NFW Wizard "Rec Pocket" and "Pocket Cutting"
Thanks TP
or i may not be using NFW Wizard.
Last Edit: March 06, 2013, 02:47:28 PM by Kenneth
Logged
Kenneth
Overloaded
4,922
Reply #23 on:
March 06, 2013, 02:59:12 PM »
There are 2 pocket wiz's in the free suite w/no corner rad. option.
You must not be referring to NFS.
Logged
Kenneth
279
Reply #24 on:
March 06, 2013, 03:04:40 PM »
that must be it.
Thanks Overloaded
Logged
Kenneth
picks27t
13
Reply #25 on:
May 11, 2013, 03:30:58 PM »
Can not get to bottom half of screen resolution is 1024x768 any help from anyone?
Logged
Kenneth
279
Reply #26 on:
May 11, 2013, 04:22:35 PM »
you should check to see if the background image is blurred also.
and in general settings put a check at "auto enlarge"
Logged
Kenneth
picks27t
13
Reply #27 on:
May 11, 2013, 04:51:59 PM »
Could you tell me were to find Auto enlarge
Thank you a lot of this is new to me
Logged
Ron Ginger
925
Reply #28 on:
May 11, 2013, 06:24:39 PM »
On the top menu bar, under the Config item there is a general config screen. Its got a lot of settings on it, down near the bottom just to the right of center is the auto screen enlarge
Logged
picks27t
13
Reply #29 on:
May 12, 2013, 10:18:28 AM »
Thank you Men i now have a full screen
Logged
Print
Pages:
1
2
3
4
5
6
Go Up
« previous
next »
