Hello Guest it is April 18, 2024, 03:32:54 PM
Author Topic: Different Files  (Read 5796 times)
Offline kolias
  •  1,154 1,154
Different Files
« on: April 07, 2011, 10:07:08 AM »
RICH you were right about gmax / gimp software and so I will stick with my Acad v14 to do my work.
I made the attached dxf but when I import it to LC is very different. Can you please tell me what is wrong?
Nicolas
Re: Different Files
« Reply #1 on: April 07, 2011, 10:29:15 AM »
Hi Nic,
  I'll try to help you until Rich gets back.
Your DXF has too many entities for the arcs. see pic
I converted the dxf to polylines and saved as R12 and it does much better with LCam.
Try this one.
Russ
Re: Different Files
« Reply #2 on: April 07, 2011, 10:30:07 AM »
I don't have lazyCAM here, but I'm guessing that it's because you are using spline fit polylines. Either explode them, or use regular splines and save as .v12 dxf. I'm pretty sure that LazyCAM can't read those properly.
Offline kolias
  •  1,154 1,154
Re: Different Files
« Reply #3 on: April 07, 2011, 01:45:42 PM »
I’m not an expert in Acad but I try to learn it again. It’s true that I used too many entities and spline fit polylines to make the design and I thought that was the best.
Now I will follow your suggestions
Thank you both for the help
Nicolas
Re: Different Files
« Reply #4 on: April 07, 2011, 02:20:43 PM »
Spline fit polylines are a no-no for CAM.
Regular splines are OK, IF you use v12 .dxf
Offline kolias
  •  1,154 1,154
Re: Different Files
« Reply #5 on: April 07, 2011, 02:34:55 PM »
Wow, what a difference
I exploded the lines and saved the dwg in R12 and now LC shows a perfect drawing. Thank you
BTW Gerry I dont have any “regular splines” in my Acad. Under the Draw Menu among other shapes I only have “Spline” or normally I type at the command “spline”. I only have Acad V14, perhaps regular splines are only available in newer / older versions?
However the text is not shown in LC properly. I tried to use different fonts in Acad but LC does not import the fonts properly. Then I removed the text from my dxf and I tried in LC to stick at the bottom part of my dwg my text with the Text menu from LC. That didn’t work either because my drawing almost disappeared,
Is there any trick to get some text in LC on a dwg that I import into LC?
Nicolas
Re: Different Files
« Reply #6 on: April 07, 2011, 02:43:40 PM »
When I said "regular splines", I meant "Splines". The ones you have. :)
No easy way of getting usable text in R14. I recommend using something like this to create .dxf text, then copy and paste it into your drawing.
http://www.dwgtool.com/outline.htm
Offline kolias
  •  1,154 1,154
Re: Different Files
« Reply #7 on: April 07, 2011, 03:09:16 PM »
Thanks Gerry
Outline Art looks a pretty good one and thanks for the info. I will keep it in mind when I’m ready to cut my first sign
Nicolas
Offline kolias
  •  1,154 1,154
Re: Different Files
« Reply #8 on: April 07, 2011, 05:57:59 PM »
Hey Gerry
I downloaded this font program to give it a try before buying but doesn't recognize my Acad. I click on the "Set AutoCAD ARX command" and it says R14 Not Found.
Any ideas?
Nicolas
Re: Different Files
« Reply #9 on: April 07, 2011, 06:56:20 PM »
Use the standalone version that creates .dxf files, and open the .dxf's in AutoCAD and copy and paste them into your drawing.
