Hello Guest it is April 24, 2024, 02:24:56 PM
Author Topic: How to match BobCAD options with Mach3 configuration  (Read 8088 times)
« on: March 30, 2011, 08:40:53 PM »
BobCAD V21 has options for the g-code in the CAM side for g-code and are shown in the two jpg attachments.
I am using a Gecko G540 controller/drivers.
Is there a "best" set of settings for Mach3?
What are the matching settings in Mach3 for the options in BobCAD?
Steve.
Offline Graham Waterworth
  •  2,673 2,673
  • Yorkshire Dales, England
Re: How to match BobCAD options with Mach3 configuration
« Reply #1 on: March 31, 2011, 11:19:32 AM »
It looks fine to me as it is set in your pictures.
Graham
« Reply #2 on: March 31, 2011, 02:04:41 PM »
Graham,
I've used those BobCAD settings for several years with a different CAM software package.
What would be the matching selections in Mach3 configuration?
Should distance mode be absolute or incremental?
Does incremental/absolute make a difference for the Wizards?
I have attached the general logic configuration, are there any changes that would match the BobCAD settings any better?
Steve.
  •  2,673 2,673
« Reply #3 on: March 31, 2011, 05:34:31 PM »
Distance mode in Mach3 should be set to absolute and ij mode set to inc.
Graham
« Reply #4 on: April 28, 2011, 06:13:40 AM »
Steve, I am going to have the same combo as you, can you tell me what post processor you chose in Bobcad?
     Ed C
« Reply #5 on: April 28, 2011, 10:33:24 AM »
Ed,
I use the basic one, but it is less than good.  I have to make changes in the code after the fact most of the time.  The real solution would be for me to learn how to edit the post processor, but I just don't have the time.
If you don't use the macro for "start program" then you have other problems.  If you use the macro "start program" then it inserts g-codes that cause Mach to do unusual things.
I've accepted that there aren't that many BCC/Mach combination users.
Steve.
