Welcome, Guest. Please login or register.
Did you miss your activation email?
May 20, 2013, 09:45:46 AM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Tangent Corner
| |-+  Tangent Corner
| | |-+  Mill head motor retrofit
Pages: 1   Go Down
Print
Author Topic: Mill head motor retrofit  (Read 695 times)
Overloaded
Global Moderator
Offline Offline
View Profile
« on: March 08, 2011, 10:27:35 PM »
Howdy all,
  My Supermax mill has a busted up pulley in the head.  Sad (not much unlike mine  Roll Eyes )
Anyway, it is very similar to a BP Variable type except there is no "step down" on the top of the upper housing.
I want to replace the original motor with an inverter duty motor that I have and use a VFD.
I can easily modify the mounting for this but am looking for advise on what pulley type and size to use.
Should I gear it UP ? or DOWN ? or 1:1 ?   Undecided
Single or double V ... or timing type ? Size ?   Undecided
 My little 1hp BP (8 speed) only has 1 seemingly small V belt.
It's just 2 HP and the motor is rated to 5200 RPM.
It will also produce 2 HP at very low rpm so I might not even need the backgear but it will be there if I do need it.
Russ
Logged
"I haven't failed. I've just found 10,000 ways that won't work."         Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #1 on: March 09, 2011, 04:56:28 PM »
Ok, so I went ahead and ordered 2 double "A" (1/2") V-belt pulleys.
4.25" and 3.75" with taper lock bushings.
They will interchange so I have the option of  1.13:1 or .88:1
Planning to go with the reduction.
Russ
Logged
Abe Lincoln
Graham Waterworth
Administrator
Online Online
West Yorkshire, England
View Profile WWW
« Reply #2 on: March 11, 2011, 05:14:53 AM »
I would go with the .88 ratio too, better to have that little bit more torque than the extra 600 revs. The V belts should run quieter at high revs, from experience tooth belts at above 4000 rpm get very noisy.
But that's only my opinion  Grin
Graham
Logged
G-Code is on the cutting edge
Autovalues Engineering, CNC machining specialists, Bradford, England
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #3 on: March 11, 2011, 07:24:08 AM »
I highly value your opinions Graham, even when they are in agreement with my own. Grin
Russ
 Smiley
Logged
Abe Lincoln
edvaness
Active Member
Offline Offline
View Profile
« Reply #4 on: March 15, 2011, 05:15:08 PM »
I agree, you need the power over the speed.
Logged
Ed VanEss
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
