Welcome, Guest. Please login or register.
Did you miss your activation email?
May 24, 2013, 02:10:43 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Tangent Corner
| |-+  Tangent Corner
| | |-+  Anyone here has EDM machine?
Pages: 1   Go Down
Print
Author Topic: Anyone here has EDM machine?  (Read 342 times)
fer_mayrl
Global Moderator
Offline Offline
View Profile
« on: March 01, 2011, 05:07:15 PM »
hello guys,
Im looking for someone that has an EDM machine that could manufacture a couple of parts for me.
This is a failry simple job, if you have the equipment.
Im attaching a PDF drawing of what is needed.
Just two parts are needed.
Critical stuff, both pieces should mate perfectly so maybe ground surfaces are required. The end of the workpiece where the conical part is, should be ground also.
material is plain steel for now since this is just a prototype, final products would have different outside dimensions and different material.
Anyone looking for some side bucks?
Pls let me know
Best Regards
Fernando
* EDM workpiece.pdf (39.11 KB - downloaded 65 times.)
Logged
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
