Welcome, Guest. Please login or register.
Did you miss your activation email?
May 24, 2013, 06:47:12 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Tangent Corner
| |-+  Tangent Corner
| | |-+  Punch or Drill
Pages: 1   Go Down
Print
Author Topic: Punch or Drill  (Read 400 times)
Overloaded
Global Moderator
Offline Offline
View Profile
« on: February 24, 2011, 03:51:15 PM »
Hey All,
  To punch or drill .050" dia holes in .035" thick 260 (half hard) brass ...... that is the question.
There will be many, many to do.
A punch seems best but not sure about the punch dia. to material thickness ratio.
The punch will be quite fragile. Any thoughts on this ?
But to drill, initial speed and feed calcs show 18K + rpm with a .0002 or so chip load.
And the set-up would probably require two spindles.
Anybody got any light to shed ?
I'm torn  Undecided
Russ
Logged
"I haven't failed. I've just found 10,000 ways that won't work."         Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Tweakie.CNC
Global Moderator
Offline Offline
Super Kitty.
View Profile WWW
« Reply #1 on: February 25, 2011, 03:45:24 AM »
Russ,
I think getting a punch through is no problem but the material has to be held correctly when the punch is withdrawn, any movement here would risk a breakage. The punch could have a short head and reasonable diameter shank for strength so I would not see that as a problem but holding the material down is another story.
Logged
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #2 on: February 25, 2011, 09:57:39 AM »
Hi Tweakie, I did a test and verified your thoughts.
I used a hard urethane bushing as a stripper and it punched much better than I had expected.
The fixture will have two punches relatively close together so the shank will be .25" max.
Should be no problem punching, greatly simplifies the job !
Thank you for your advise / input.
Russ  Smiley
Logged
Abe Lincoln
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
