Hello Guest it is April 19, 2024, 07:44:27 AM
Author Topic: mac logo  (Read 27409 times)
Re: mac logo
« Reply #20 on: May 10, 2011, 07:06:12 AM »
Sorry
« Last Edit: May 10, 2011, 07:25:01 AM by Ya-Nvr-No »
Re: mac logo
« Reply #21 on: May 10, 2011, 06:59:58 PM »
 ;) here is the file need to ad more detail on some parts...
Re: mac logo
« Reply #22 on: February 15, 2012, 04:59:14 PM »
here is another free code just post a picture of the finish work. thanks.
Re: mac logo
« Reply #23 on: December 26, 2013, 11:40:43 AM »
Hello,
which program you use that it have exstansion *.nc.
Thank you for answer.
Best regards, G
Re: mac logo
« Reply #24 on: December 28, 2013, 01:36:07 AM »
cambam has a *.nc extension.
Re: mac logo
« Reply #25 on: December 29, 2013, 09:05:15 AM »
Hello,
There are many programs that produce gcode with the *.NC extension. The file itself, is actually a text file (and can be opened and edited using MS Notepad). The default gcode extension of files in Mach3 is *.tap Although it too, can load and run text files, as long as the gcode they contain is in the correct format. I use MeshCAM Art to produce the gcode for 3D carvings (which outputs the files as *.NC) this makes it easy to distinguish which files are 3D sculptures (*.NC), or simple cut-out programs (*.TAP). Hope this helps you in understanding the differences.
Best regards, G
