May 22, 2013, 04:03:19 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Tangent Corner
| |-+  Tangent Corner
| | |-+  Power Supply Question
Pages: 1   Go Down
Print
Author Topic: Power Supply Question  (Read 325 times)
Overloaded
Global Moderator
Offline Offline
View Profile
« on: February 10, 2011, 12:15:14 PM »
Hi All,
   I gutted a piece of equipment from a financial institution and pulled this PS.
I've never seen one quite like this one.
110VAC in, says 28V out of the blue cap. (40,000uF, 40 VDC, Max surge - 50 VDC)
The gray cap says 3uF 660v. What is its purpose ?
How can I determine the MAX wattage of this unit ?
 Smiley
« Last Edit: February 10, 2011, 01:47:23 PM by Overloaded » Logged
"I haven't failed. I've just found 10,000 ways that won't work."         Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
ostie01
Active Member
Offline Offline
View Profile
« Reply #1 on: February 10, 2011, 12:30:57 PM »
You will need to know the current it can deliver.
You cannot calculate the wattage only knowing the output voltage.
There's an AC capacitor and a DC capacitor for filtering DC output currant.
The output currant is more stable with the output capacitor, will prevent small ripples of voltage.
Jeff
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #2 on: February 10, 2011, 01:56:18 PM »
Hi Jeff,
   Thanks for the info.
No way ? I was hoping there was a way to determine the current available.
The voltage is probably too low for any practical CNC app anyway, I suppose.
To the dump !
Thanks again,
Russ
Abe Lincoln
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
