Hi. First, i would like to thanks Joakim for everything he did and does for this community.
Second, i want to comment my problem, hope someone can help me: I have a controller wich works fine. Under windows calibration everything appears normal. After install plugin, activate in Mach3 and all that stuff, everything works fine BUT!!! the continuous jog. I can switch between Step and Continuous and in step it does what it should, and directions are correct, as configured in Plugin Config. But for the other mode, it is like the moving knob for X Y Z motion is not working.
Is there something you think i could be doing wrong?
Thanks again!!!
