I am writing to the forum in hopes I can solve an issue with Mach3 and a gamepad as a controller.
Before I disclose my issue a little background.
The game pad is a Logitech Dual Shock Game pad.
I have tested on 2 PC's.
PC#1 For CNC Machine. Windows XP Pro SP3 on IBM Netvista P4 w 2GB Ram, 160GB HD
PC#2 Test Machine. Windows 7 Pro on Lenovo W520 w 32GB Ram, 250GB SSD C drive, 2 x 1 TB mirrored Data drives.
I have Mach3 installed on both machines including the JoyPAD v2.0 plugin by Joakim Hjort.
Also have Joystick 1.0a by Art Fenerty installed on both machines.
My issue. The joysticks do not activate the motors. All the push buttons seem to work ok and using the ALT-LEFT trigger button and then moving the left joystick works to change screens using joystick. Pushing the right joystick button activates the E-Stop. It seems that only the jogging is not working.
This behavior is the same on both computers.
If I activate the Joystick 1.0a plugin by Art, the motors respond to the movement of the joysticks on the Logitech gamep pad.
I have tried uninstalling and installing several times, combed through the manual, and seached the forum and internet and cannot seem to find a solution.
I would appreciate any suggestions the forum has regarding this issue.
All the best.
