Hello
Guest
it is
April 19, 2024, 04:36:34 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
probe input
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: probe input (Read 6104 times)
gjmoule
20
probe input
on:
February 04, 2011, 10:04:07 AM »
Hi, have been trying to fit a z auto height probe. the breakout board is at
http://hairyraho.com/stepper-driver-board-tb6560-3v2/
Cannot find a input signal , have set to pin 15 port 5 and all sorts of configurations with no luck. Has anybody had success with this board or does it just no have a pin 15 available? Am using pins 10,11,12,13 no trouble. perhaps there is another way of getting an input signal?
thanks
Logged
Tweakie.CNC
9,198
Super Kitty
Re: probe input
Reply #1 on:
February 04, 2011, 12:22:54 PM »
Is this the board you have ?
Logged
Carnoustie, Scotland
Re: probe input
Reply #2 on:
February 04, 2011, 01:11:03 PM »
Should it not be port 1?
Logged
gjmoule
20
Re: probe input
Reply #3 on:
February 05, 2011, 01:29:44 AM »
Hi, yes thats the board tweakie, have tried port 1,with no success. The web site that i have quoted says its port 5 and it says port 5 on the board itself.
thanks
Logged
Re: probe input
Reply #4 on:
February 05, 2011, 03:04:44 AM »
I suspect when it is talking about Port5 it is referring to the actual socket on the board, there is no Port 5 in Mach as far as I know. Parallel port setups use Port 1 and if dual PP then also Port 2.
Logged
Tweakie.CNC
9,198
Super Kitty
Re: probe input
Reply #5 on:
February 05, 2011, 03:05:56 AM »
I understand that it says port 5 but I think Hood is right all your Mach configured inputs and outputs will be port 1.
Locate a free input pin (green connector) and map that pin number using port 1 to 'probe' within the Mach 'ports and pins' setup. That should do it.
Logged
gjmoule
20
Re: probe input
Reply #6 on:
February 05, 2011, 06:17:39 AM »
Hi, have set port to port 1 , pin 15 but am getting no input on screen. Have tried the auto setup but no input is detected. Am getting 5v between gnd and 5v as marked on the spare 5 pin connector .
Logged
Tweakie.CNC
9,198
Super Kitty
Re: probe input
Reply #7 on:
February 05, 2011, 06:44:02 AM »
Probe should be set active low. If you have ports and pins set correctly touching pin 15 to GND will illuminate the probe LED.
Logged
ger21
6,295
Re: probe input
Reply #8 on:
February 05, 2011, 06:46:06 AM »
It says you only have 10-13. What is CCOM connected to? That looks like the only other input?
Logged
fixittt
289
Re: probe input
Reply #9 on:
February 07, 2011, 11:33:50 AM »
if your home switches are normally open then you can wire a couple of them in series and use 1 pin for 2 home switches, then put the probe on the open pin that one of your home switches was on. say pin 13.
Logged
Print
Pages:
1
Go Up
« previous
next »
