I'm using the Mach blue screen set, and on the right side of the screen there's a Z plate offset, I'm thinking of modifing the code of that Z plate offset.
When Z plate offset is pressed, the Z axis lower down and stop when switch is tripped, and from here I want to add some code so that it raise to 13.7mm then fire torch, woul'd anyone be kind enough to provide this code for me?
thx
