Hello Guest it is June 09, 2026, 02:03:57 AM
Author Topic: Making a boring tool an internal threading tool  (Read 20637 times)
Offline Bloy
  •  158 158
« on: January 22, 2006, 01:26:55 PM »
..For general info....
Here are several pictures showing the grinding I did to convert a smallish boring tool.  The third picture is the resulting thread on an aluminum tube using Brian's simple threading wizard.
« Last Edit: January 22, 2006, 01:40:14 PM by Bloy »
ynneb
Re: Making a boring tool an internal threading tool
« Reply #1 on: January 22, 2006, 05:44:55 PM »
Nice post
« Reply #2 on: January 22, 2006, 06:40:29 PM »
You are having to much fun :) NICE work!
I was at a friend's house making threads in wood :) We did the square threads with the threadmilling in the NFS set..
www.newfangledsolutions.com
www.machsupport.com
Offline Bloy
  •  158 158
« Reply #3 on: January 23, 2006, 05:23:48 PM »
Brian,
  Did you do the milling of wood threads in one pass?  Or did you set up a "cycle" to cut the square threads with
multiple passes?  Oak?  Maple?  soft woods?  This is interesting.  What was it that you were making?  Did you have a high speed spindle?   I'd like to see pictures of that setup.  Did you photograph the session?
  I have a router table with some excess Z travel, rigid, and itching to fool around with mill threading(at least on short stubby pieces).  Eventually I'll be putting on the table a 5th axis(or simple sensored spindle) for slightly longer items....Yand A axes are slaved.  I can lower the table more, but it isn't yet set up to do so easily.
You piqued my curiosity!
John(bloy)
P.S.  just testing http://www.machsupport.com/Mach2/3/4 Forum
« Last Edit: February 01, 2006, 04:31:04 PM by Bloy »
« Reply #4 on: January 23, 2006, 07:47:14 PM »
I will see if I can get him to cut one more thread so I can take a pic of it cutting:) It was not a high speed spindle, we cut the threads with a series one CNC in one pass. The wood was walnut and I think we were cutting it at 40IPM.
I will see him in a few days and I will see if I can get him to do it again!
www.machsupport.com
« Reply #5 on: August 31, 2006, 08:42:30 AM »
I am looking for thread milling tools.  I want to get the single tooth kind so I can do various threads.  I found one at Harvey Tool:
http://www.harveytool.com/products/product_detail.php?product_id=71000-C3&category_id=1&product_family=Thread+Milling+Cutters
I would really like an indexable cutter but I have not been able to find one.
Any insight would be helpful.
Offline John S
  •  111 111
  • Nottingham England
« Reply #6 on: August 31, 2006, 04:27:03 PM »
I do a lot of thread milling.
Anything that has short threads gets milled instead of screwcut.
Because I'm tight and begrudge spending mega$$ for a thread mill I use my own.
Small threadmills are just taps with all the flutes except one ground off.
Larger ones are just one insert out of a Coventry die head mounted in a holder.
With an example piece that's been milled in one pass.
That same holder also serves as an internal threading tool on the lathe.
John S.
