I installed a new driver board last night to see if some reason it helps with my SS problem. I leave mach just sit there then come back jog something, enter some gcode and make it run and then just sit again. I close mach and come back and reopen mach etc...
If I understand correctly fixture save is what saves the xyz coordinates for the next time Mach3 starts again, it will have the numbers at the same previous setting when you exited Mach3.
Why doesn't it ask every time I exit Mach3 and can I save it before exiting to make sure it opens back up to the same place it was?
