A year ago I got my machine working (Mach3, ncPOD, xp sp3), mothballed it for months, and forgot everything I learned setting it up the first time...
Now I come to use it again, after 4 months away from it, it doesn't work.... no jogging happens (even in DRO's) and no response to gcode, unless I specify the parallel port driver in mach instead of ncPOD. Motors all tight and torqued up, lights on drivers lit, so no problems there.
When the pod is switched on, the red and blue lights show continuously, the green flashes slowly. It stays like this regardless of whether the pc is on or off, or if Mach is running or not. Disconnecting the usb lead at either end causes the blue light to blink (which tells me no usb connection)
So I reloaded Mach and all drivers, tried it , with same response. Even ran chkdsk to see if PC had a problem. None there.
Also, despite seeing 'Deskpod-ncPOD-plugin-3.00.--A.Fenerty-B-I'' 'in the motion control hardware sensed!' dialogue at start of mach, I'm still only seeing 'ncPOD v2.00.059 config' in the dropdown under 'plugin control', plus an ominously empty config box... (see attached.) I seem to remember something automatically appeared there the last time I did all this I mean in the config box, sorry.
I don't remember how I solved this last time I did all this... I know I had same problems a year ago, forgot to write down what I did.
Rich B
