Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portuguese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 19, 2013, 12:42:23 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Machsupport Forum
Third party software and hardware support forums.
SmoothStepper USB
(Moderator:
Warp9TD
setting up encoders with smooth stepper. Basic help needed
Pages:
1
Go Down
« previous
next »
Author
Topic: setting up encoders with smooth stepper. Basic help needed (Read 961 times)
john15
Active Member
Offline
on:
December 28, 2010, 12:57:37 PM »
Hi all
I have some basic questions about using encoders with SS
I have two encoders with a,b,i , 5v,& ground wires. Single ended I believe
I believe I connect to port 3 pins 1,2 3 and 5v, ground
set up Mach input encoders to port 3 a pin 1, b pin 2
How do i see any result of the encoder IE a position box
How do I tell mach the resolution of the encoders
can I set a pause if the encoder count and Mach's position differ by X
Thanks for any help
John
Logged
Mad rush on a treadmill gets nowere
Active Member
Offline
Carnoustie, Scotland
Re: setting up encoders with smooth stepper. Basic help needed
Reply #1 on:
December 28, 2010, 02:39:28 PM »
You can input them on port 3 as you thought, in fact you could likely use port 1 or 2 as well.
Port 3 has 6 inputs, three of which have differential capability but you can still use them single ended.
To set up in Mach its just Config menu then Ports and Pins then Encoder/MPGs. You then just set the port and pin numbers and can also set the counts per unit and Velocity although I am not sure if Velocity is actually needed for encoders.
You will see the readouts on I think the Settings page and if wanting to fault if there is a discrepancy you would need to write a Brain or Macropump. How effective it would be I dont know as it will all depend on the error size you set, how fast the axis is moving etc . The Brain/Macropump just run at 10Hz if I recall
Logged
john15
Active Member
Offline
Reply #2 on:
December 28, 2010, 08:15:52 PM »
Thanks for the reply
It is a real shame that ther is not a more detailed manual for SS after it has been a strong part of Mach for quite some time now.
I am reluctant and financially embarased to have to purchase the add on board to achive what ought to be an easily implimented part of SS
I know Mach is not and doesnt pretend to be closed loop but by now this kind of routine ought to be easily implimented by the likes of SS, after all it acsepts encoder input so it ought to be easily implimented. Perhaps I am expecting too much.
John
Logged
Active Member
Offline
Reply #3 on:
December 28, 2010, 08:27:10 PM »
The SS was meant as a parallel port replacement really so it does most of what Mach does except with a higher pulserate so really it shouldnt be expected that it does more.
The space on the SS is limited so Greg has had to do a lot of juggling to fit everything on. I have seen Greg mention that future versions of the SS will have more room and may well do more advanced stuff, then again they will likely be more expensive.
Logged
john15
Active Member
Offline
Reply #4 on:
December 28, 2010, 09:11:57 PM »
Such is life
I wanted a rolls royce for £50 and ended up with a rolls can'ardly!
Logged
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Mach SDK plugin questions and answers.
===> Finished Plugins for Download
=> VB and the development of wizards
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Screen designer tips and tutorials
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> Machscreen Screen Designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
=> Show"N"Tell ( What you have made with your CNC machine.)
=> Building or Buying a Wood routing table.. Beginnners guide..
=> Show"N"Tell ( Your Machines)
G-Code, CAD, and CAM
=> G-Code, CAD, and CAM discussions
=> LazyCam (Beta)
=> LazyTurn
=> GearoticMotion Preliminary testing
=> Tempest Trajectory Planner
=> Contec
=> CS-Lab
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Third party software and hardware support forums.
=> Galil
=> Newfangled Solutions Mach3 Wizards
=> Newfangled Mill Wizard
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
=> Promote and discuss your product
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
=> Forum suggestions and report forum problems.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
