Hello Guest it is March 28, 2024, 02:03:47 PM
Author Topic: Mach3 & Galil stepper motor with encoder feedback  (Read 3151 times)
« on: December 28, 2010, 10:03:24 AM »
I recently added an encoder on the x axis of my router. The system controller is a Galil 2108 card from. The feedback is from  a rack and pinion gear mounted on an encoder.
Does anyone know how to configure Mach3 to use the encoder feedback to drive the x axis rather than the open loop control that I currently have. Is this possible to do with this setup or does feedback only work iwith servo motor? I am able the see that the encoder does work properly in the Smartterm (Galil) as the motor position does increments/decrements  as the position changes.
