Hello Guest it is March 29, 2024, 07:38:32 AM
Author Topic: Odd Issues with NFS Wizards  (Read 3725 times)
« on: December 26, 2010, 01:00:28 AM »
I have some odd issues with the NFS wizards were I select my material, then my tool, then say for example I go into Cut Circle.
I enter all my values and click Preview and nothing happens, if I click Post code nothing happens.  If I click cancel I get back to the Milling Operation Screens but clicking Exit does not return me to the main Mach Screen and really does nothing.
Operation List works, and shows a blank and Verify Toolpath works which shows no tool paths. Clicking on Exist still does not return me.
When this occurs, I generally have to keep swapping screens back and forth before it will actually start working correctly.
I upgraded to version 2.85 and I still have the issue and I'm using the very latest lock down version of Mach R3.042.040
All the Mach menu items work fine
Re: Odd Issues with NFS Wizards
« Reply #1 on: December 26, 2010, 03:05:10 PM »
Do you have a license for the NFS wizards?
« Reply #2 on: December 26, 2010, 06:09:26 PM »
Yes, it's registered and they work most of the time but sometimes I get into this rut and about the only way to get of the screens is to exit Mach3.
Richard
« Reply #3 on: December 30, 2010, 08:37:06 AM »
Can you tell if thre is any data dependency? Dos it only get into this state when you have some error like a zero radius?
The wizards really have no control of the button action- if mach sees the button press then it calls the wizard code,. Somehow mach must not be detecting the clicks. This is not on a touch screen is it? My touch screen often doesnt respond to touches, even though it beeps.
