Hello
Guest
it is
April 25, 2024, 12:33:18 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Using Mach3 and Camworks
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Using Mach3 and Camworks (Read 9011 times)
debutpic
7
on:
November 11, 2006, 10:49:33 AM »
Hello all
I use since several years the CAD/CAM package Solidworks/Camworks
but do you know if a postprocessor exist for Mach3 ?
thank's
Logged
Graham Waterworth
2,673
Yorkshire Dales, England
Re: Using Mach3 and Camworks
Reply #1 on:
November 11, 2006, 01:55:30 PM »
A Fanuc 6m or 15m post should be very close.
Graham.
Logged
debutpic
7
Reply #2 on:
November 12, 2006, 04:06:49 AM »
Thank's Graham,I will try with this post.
Do you work with Camworks and Mach 3 because
I did not see of Topic which uses this two software?
Last Edit: November 12, 2006, 04:16:15 AM by debutpic
Logged
Graham Waterworth
2,673
Reply #3 on:
November 12, 2006, 04:08:25 AM »
No.
Graham.
Logged
debutpic
7
Reply #4 on:
November 12, 2006, 04:24:04 AM »
Do you know or I can find a good support for Camworks and Mach3 ?
Logged
Graham Waterworth
2,673
Reply #5 on:
November 12, 2006, 04:27:33 AM »
This is the best place for Mach3, Camworks, don't know.
Mach3 has Lazycam built in and will do alot of what you want, you may not need Camworks.
Graham.
Logged
Print
Pages:
1
Go Up
« previous
next »
