Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portuguese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 21, 2013, 08:03:22 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
Mach Screens
Works in progress
3 PAGE LATHE SCREEN - WIZARD ADDITIONS
Pages:
1
2
3
4
5
6
7
Go Down
« previous
next »
Author
Topic: 3 PAGE LATHE SCREEN - WIZARD ADDITIONS (Read 5662 times)
Global Moderator
Offline
Re: 3 PAGE LATHE SCREEN - WIZARD ADDITIONS
Reply #10 on:
November 27, 2010, 01:08:11 PM »
Wes, Sorry about that as it went to my draft folder. Just sent it a few minutes ago.
Dan13
Active Member
Offline
Reply #11 on:
November 27, 2010, 01:21:43 PM »
Quote from: DaOne on November 27, 2010, 01:04:13 PM
Dan,
Here is what I got so far on the wizard you have requested. I am still finishing up on the code. Let me know what you think.
Wes
Hi Wes,
Looks great! Exactly what I was meaning. Just a minor display note - the workpiece image is not symmetrical about the centre line.
DaOne
Active Member
Offline
Reply #12 on:
November 27, 2010, 01:26:33 PM »
Rich,
I got them. They look great so far. I like how they are commented in the G-code. I think this will help allot when we start compounding things to make programs. I have started writing the record functions and might need a little help from Scott. Still reading a few things.
DaOne
Active Member
Offline
Reply #13 on:
November 27, 2010, 01:31:17 PM »
Hi Wes,
I know its not perfect. Most of the image is from the standard wizards images. Looks like they were planning to make this but never did. Anyways I really hope that someone with more graphic skills than I can help on that part. I get frustrated quickly working with images. I do however use solidworks and can create the shapes and maybe even use real view to render them life like. Too many irons in the fire.
Last Edit: November 27, 2010, 01:33:01 PM by DaOne
Dan13
Active Member
Offline
Reply #14 on:
November 27, 2010, 02:29:09 PM »
Wes,
A quick image. See attached.
Global Moderator
Offline
Reply #15 on:
November 27, 2010, 02:31:31 PM »
DaOne,
Yep, forgot all about that, it's for dummies like me who only use them once in while and suggest that it is kept or added to in all the others. I can help with the bit maps.
Later,
DaOne
Active Member
Offline
Reply #16 on:
November 27, 2010, 02:45:42 PM »
Dan,
Looks Great. Any chance you can make it 275 x 253 pixels? Maybe even make the small one too for the wizard selector? They are 150 x 150 pixels.
Rich,
Yes I will be adding comments to all the code. It will really help in a long program.
Global Moderator
Offline
Reply #17 on:
November 27, 2010, 03:08:42 PM »
Need a new one for the threading bmp, nothing fancy, just show a rod with thread on the end and a name. The current one was just a screen shot and looks like........
Later the tool paths, when appropriate, can be added to them.
Like the teamwork, just think what could get done if we had about ten people in here!
That said, i wil be traveling tomorrow, so out of pocket for a day.
Global Moderator
Offline
Reply #18 on:
November 27, 2010, 06:38:45 PM »
G32 WIZARD
CURRRENT STATE OF THE MACHINE
Threading of the part is complete, spindle is turning / coolant is on , and X & Z axes are at some point along the axis. It is assumed that that current
modes ie: inches / exact stop and tool etc have not been changed. It's also assumed the user saved settings in the whatvever thread wizard was
used and has not closed the current thread file.
1. Spindle off
2. Reset / Estop/ the axes are disengaged for safety
MANUAL MEASUREMENT
The user will measure the thread, test with a thread gage, or try a nut or something to determine how much they want to remove from the oversize thread.
Most users don't even have a thread mic. I thought about having the wizard calculate what to do based on some measurements. It just opens up a can of
worms ( actual axis resolution, pitch dia basis, measurement averaging ) that is not worth having the wizard compute the correction. It's not only the as cut
diameter, but also lead , tool, and other things that can affect what the user ended up with. So KISS is going to be used such that only some spring
pass is generated based on whatever the user inputs.
INPUTS FOR THE WIZARD:
The X must be positioned and the same feedrate which was used in the threading wizard. Z start would usually be positive 3 to 5 x pitch from Z=0 of the piece, but,
who knows what someone used. There is a difference between say using Scotts, the Simple Threading, or a G76. So the question is where can the data
for inputs best come from ( other than manual input). Note that the G32 will not provide for pullout other than "0" setting for a chamfer at the end of the thread.
Scott, not knowing just what data you can or can't get may determine how the wizard is done ( or maybe shouldn't be done), thus some questions as follows:
? assume the current Z & X can be had from the DRO's
? can you extract data from the saved settings of the Simple Threading or your wizard.
? Is it possible to extract the last lines of code from a file and use them
Here is a list of data for the wizard: (> meaning data not input by the user if possible)
X> CURRENT LOCATION
X>END
Z>CURRENT LOCATION
F> FEEDRATE
X= USER INPUT FOR THREAD ADJUSTMENT
Z= USER INPUT ( MAYBE NEEDED IF CLEANING UP A MULTIPLE START THREAD / DON'T KNOW IF WE WANT TO GO THERE!)
F= USER INPUT ( i DON'T KNOW IF I WANT TO GET INTO THIS ONE.......EXPLAIN LATER)
N=USER INPUT FOR NUMBER OF PASSES
So the code the wizard provides will reposition the X & Z , an x move to a position, G32 move to thread the piece,
and a return after the threading to a position.
DaOne
Active Member
Offline
Reply #19 on:
November 28, 2010, 01:11:41 AM »
Ok Dan,
Give this a go... please be careful as it needs to be tested before you can rely on it. Also Mach does not display the stock correctly but the cuts look ok from the DROs. I would recommend cutting air a few times before using it to do any work.
ODArc4.zip
(34.1 KB - downloaded 84 times.)
Pages:
1
2
3
4
5
6
7
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> CS-Lab
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Mach3 Wizards
=> Newfangled Mill Wizard
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
