Hello Guest it is June 10, 2026, 03:55:48 PM
Author Topic: Which Contec cards work with the plugin and which don't  (Read 411920 times)
« on: November 20, 2010, 01:58:37 PM »
Like the title say, is there a list of which ones do and which ones don't????
Mike
Offline smurph
  •  1,575 1,575
Re: Which Contec cards work with the plugin and which don't
« Reply #1 on: November 21, 2010, 10:59:23 PM »
Any of the PIO(PCI) series cards should work.  Oly the PIO-16/16T(PCI)H has been tested.
Basically, here are the list of likely candidates:
16 input / 16 output
PIO-16/16T(PCI)H - TTL (5v input/open collector output to 30v)
PIO-16/16L(PCI)H - Low voltage (12v - 24v input/output)
PIO-16/16H(PCI)H - High voltage (24v - 48v input/output)
32 input / 32 output
The "bi-directional" cards are not supported by the PIO plugin.
Steve
« Reply #2 on: January 03, 2011, 09:15:53 PM »
Hi Smurph
can we use the Contec PIO to drive the motor? step and direction? not the parallel port from my pc. want to use it for many of my machine.
ardona
« Last Edit: January 03, 2011, 09:17:59 PM by ardona »
Offline smurph
  •  1,575 1,575
« Reply #3 on: January 03, 2011, 11:36:34 PM »
Sorry, no.  That is not an option.  It's an I/O plugin only.  Have a look at the Smooth Stepper for a nice stepper motor controller that doesn't use the parallel port.
Steve
« Reply #4 on: March 30, 2011, 03:05:24 AM »
Hi Stave,
can we use this card for MPG or Encoder as input?
Regards
Ardona
Offline smurph
  •  1,575 1,575
« Reply #5 on: March 30, 2011, 10:00:25 AM »
No, it is for I/O only.  :(
« Reply #6 on: July 07, 2011, 02:32:57 AM »
i have this model PIO32/32L(PCI)H, 12-24 volt. can i use this to drive relays with 24v dc coils?
Offline smurph
  •  1,575 1,575
« Reply #7 on: November 22, 2013, 12:00:46 PM »
It depends on the current capacity of the card and the specs of the relay coils.  I have no idea what the specs of the card is.  The Contec website probably has that information.
