Hello Guest it is April 18, 2024, 06:04:31 AM
Author Topic: V2.85 fixed bug in Cut rectangle  (Read 4230 times)
« on: November 19, 2010, 03:33:30 PM »
Cut rectangle would go into an infinite loop if you requested a depth per cut greater than the total cut depth.
As usual, unzip this file in the MAch3 folder. You should wind up with a folder under Addons called Newfngled285. You can delete the old Newfangled and remove the 285 from the new name.
The zip file has been moved to the sticky topic at the top of this thread
« Last Edit: April 30, 2011, 08:03:28 PM by Ron Ginger »
