Hello Guest it is April 24, 2024, 04:34:17 PM
Author Topic: Post for Mach3  (Read 9879 times)
Post for Mach3
« on: November 08, 2010, 10:03:53 AM »
I', looking for the post to run my Master Cam MR2 (10.2.2.31) also says Ver. 0.17.1.167. I would like to do my drawning in my autocad and run through my Master Cam which I use in my shop. Any help would be good.
Re: Post for Mach3
« Reply #1 on: December 04, 2010, 08:13:05 AM »
May I express my master no information offline.
Don't understand the reply....sort of like a cypher. ???
« Last Edit: December 04, 2010, 08:16:23 AM by RICH »
Offline DaOne
  •  236 236
Re: Post for Mach3
« Reply #2 on: December 04, 2010, 05:03:18 PM »
What version of Mastercam? X - X5, lathe or mill post? MR2 doesn't tell me much. Thats just the maintenance release.  I have been working on a lathe post for X5
Re: Post for Mach3
« Reply #3 on: March 28, 2012, 03:49:41 PM »
i used mastercam 14 and i need to know what post to use because tha mpfan make tha machine loca loca
Re: Post for Mach3
« Reply #4 on: March 28, 2012, 06:42:16 PM »
because tha mpfan
Don't understand.. ???
Offline DaOne
  •  236 236
Re: Post for Mach3
« Reply #5 on: March 28, 2012, 07:00:13 PM »
Mpfan is a generic post for Mastercam.  If you purchased Mastercam you should have no problem getting a post from your dealer.
Re: Post for Mach3
« Reply #6 on: March 31, 2012, 09:53:51 AM »
ok but my Q WAS which post I need to ask for
Re: Post for Mach3
« Reply #7 on: March 31, 2012, 12:23:39 PM »
Well just guessing here BUT if you are using MACH3 I would ASK for a post for MACH3.
Just a thought, (;-) TP
Re: Post for Mach3
« Reply #8 on: April 01, 2012, 06:28:19 PM »
I think a regular FANUC post would work.(already in mastercam)
Will probably have to make some changes in the header file but the code will work.
Jeff
