Hello Guest it is April 25, 2024, 08:17:58 AM
Author Topic: Impact engraving plugin  (Read 359973 times)
Offline ART
  •  1,702 1,702
  • Tough as soggy paper.
Re: Impact engraving plugin
« Reply #50 on: December 01, 2010, 05:27:23 PM »
Dan:
  Two things I notice..first, use a real photo of something with black and white in it to esnure the saturation goes above 50% of grey scale.. second, make sure you hit the calculate button before cutting, the trigger length shoudl indicate the number of pulses to be put out on a line. Shoudl be about width times XSteps..Automatically set, but you do have to hiot calculate..
Art
« Reply #51 on: December 01, 2010, 10:06:09 PM »
 I had figured that out as the  file I was using was the one that robomar posted. I didn't realize that it didn't have enough definition which casued the scope to not  to display any signals because the plugin couldn't see it any differences . The problem was all in my poor choice of jpeg to use. Earlier today I copied some other pictures and ran them through the plugion and walla I could see pulses on the scope.
Sorry for the wild goose chase.
« Reply #52 on: December 02, 2010, 02:59:31 AM »
Hi Dan
I think you're confusing engraving with embossing.
The photo of the message is created with embossing (spindle) you can try this zip attached (45 x 65 mm).
Pay attention the zip photo is negative.
Andrea
--  I am sorry for my bad English, I hope I never say the wrong things  --
« Last Edit: December 02, 2010, 03:05:50 AM by robotmar »
« Reply #53 on: December 02, 2010, 05:42:54 AM »
Hi Dan
This is the result on alluninium.
Andrea
Offline obal
  •  14 14
« Reply #54 on: December 02, 2010, 06:01:04 AM »
Version is more.This me meets.
link: http://www.machsupport.com/forum/index.php/topic,11996.0.html             file     zlib.zip
  •  9,199 9,199
« Reply #55 on: December 02, 2010, 06:17:23 AM »
That's great Andrea, looks like you have the setup all sorted now.
« Reply #56 on: December 02, 2010, 10:09:18 AM »
Hi Dan
This is the correct plugin that I used.
Hi Tweakie
This is the first photo of the external "Motor Control" that I sell.
Andrea
« Last Edit: December 02, 2010, 10:15:04 AM by robotmar »
« Reply #57 on: December 02, 2010, 10:27:51 AM »
Yes that is what I did. I used the embossing picture because I didn't know enough about the impact plugin. My bad.
Dan[
quote author=robotmar link=topic=16446.msg113125#msg113125 date=1291276771]
Hi Dan
Andrea
[/quote]
« Reply #58 on: December 10, 2010, 09:07:34 AM »
Now that is a clean design and build, nice work.
« Reply #59 on: December 21, 2010, 05:27:20 PM »
what type of signal launches the Digit trig?
analyzed with an oscilloscope?
thanks and please excuse my English
