Hello Guest it is April 19, 2024, 06:50:28 AM
Author Topic: Impact engraving plugin  (Read 359425 times)
Re: Impact engraving plugin
« Reply #320 on: January 27, 2017, 08:17:17 AM »
Watch  how my solenoid was made.I guess the mechanical design is a must.In some works I can go up to 10.000, but in others at 10000 it will leave traces between two dots.
« Reply #321 on: January 27, 2017, 09:15:37 AM »
I succeeded to engrave! :) when the machine is engraving, the power supply makes a sound, something like cheep cheep! Is it ok if it makes this sound? Shall I be worried? ???
« Reply #322 on: January 27, 2017, 12:16:27 PM »
I absolutely agree with you about this. In the video it there is no enough information to understand how the solenoid was made. Also what did you use for the coil?
« Reply #323 on: January 27, 2017, 01:08:36 PM »
how should I control the power of laser power supply while engraving??
« Reply #324 on: January 27, 2017, 01:28:10 PM »
Neodimium magnets
« Reply #325 on: January 27, 2017, 01:56:48 PM »
And how do you utilize them in your solenoid?
« Reply #326 on: January 27, 2017, 02:20:45 PM »
They make the work oferece the sping
« Reply #327 on: January 27, 2017, 02:22:20 PM »
And how are they better than a spring?
  •  9,198 9,198
« Reply #328 on: January 28, 2017, 01:47:54 AM »
In your case you have to stop the engraving, change the PWM (spindle speed), then start engraving again.
This is one of the reasons I have a manual control of laser power (as shown in my earlier diagram) - I can change laser power mid session.
« Reply #329 on: January 28, 2017, 02:11:51 AM »
Hi . I talk to Tomura for His plugin(TomTom) and Hi send it to me.
I want to ask You: I have to make some special settings if I want to use for impact engraving?
